Did i use the wrong Tranny fluid???
I feel like an ***, but this is what my local Amsoil dealer told me to use for our trannys. After reading here (should of first) i'm afraid i used the wrong type! I have already put it in and it seems fine, but i can change if it's gonna mess up anything. Tell me what you think??
https://www.amsoil.com/storefront/svg.aspx
if this is wrong can i drive on it for a few days 'till i get a chance to change it again? Or should i just drive my other car 'till then? I have only drivin it 5 miles from the dealer to home.
Thanx! My only real concern is that i read somewhere here that sulfates were bad for synchros. The back of the bottle says something about some type of sulfate hypoid additive. Otherwise it's Amsoil, it's 100% synthetic, and it's the right weight. Which may be a bad way to look at it, but i'll prob change out soon with the GL-4 only fluid from their website.
go for it.
Originally Posted by wizurd
From what I've read about GL-5 it seems as if the corrosion of syncrhos is the biggest concern with factory recommended GL-4 usage. So if you don't care about your synchros
go for it.
go for it.
So are you saying GL-4 will corrode or GL-5? Sorry not trying to be a pain. What are the synchros made of anyways?!?!
We use this....but the Amsoil will not harm your tranny. http://www.forgedperformance.com/store/home.php?cat=280
Thanks!! I'll prob change it soon anyways just for piece of mind. Is there any specific "ingredient" i should be weary of??
synchronizers are the little gears that separate the gears allowing you to shift from one gear to the next smoothly. Okay, now I am confused.
Forget my explanation...see this website:
http://auto.howstuffworks.com/transmission.htm
-J
-J
So i ask this....am i going to cause any on-going damage/corrosion by allowing that fluid to stay in my tranny for the next week/100 miles or so 'till i can get the correct stuff in???
Here's the graphic sky...
Synchronizers
Manual transmissions in modern passenger cars use synchronizers to eliminate the need for double-clutching. A synchro's purpose is to allow the collar and the gear to make frictional contact before the dog teeth make contact. This lets the collar and the gear synchronize their speeds before the teeth need to engage, like this:
The cone on the blue gear fits into the cone-shaped area in the collar, and friction between the cone and the collar synchronize the collar and the gear. The outer portion of the collar then slides so that the dog teeth can engage the gear.
Every manufacturer implements transmissions and synchros in different ways, but this is the general idea.
Synchronizers
Nissan calls for GL-4 because it uses soft metals(copper) in it's transmissions. Use only GL-4 transmission fluid. If it's GL-5(even though it says it meets or exceeds GL-4), it will screw up your transmission. Nissan has synthetic GL-4 transmission fluid at their dealerships, they'll change your tranny fluid for around $75. That's pretty cheap compared to a transmission, or having your car gone for weeks on end with warranty work.
Anything that says it will work in a GL-4 application (such as the oil you have selected) is fine. Don't worry about it.
BTW, it is usually the sulfur in GL-5 oils that screws up the synchros.
