engine rebuild kits
Old Jan 5, 2007 | 04:03 AM
HoldThisForMe's Avatar
HoldThisForMe
Default engine rebuild kits
Does anyone sell an engine rebuild kit? Complete with gaskets/bearings all that jive that goes along with a rebuild? Would make it so much easier to just buy something like this.
Russ
Old Jan 5, 2007 | 07:54 AM
Q45tech's Avatar
Q45tech
Unfortunately you must measure each component to select the correct tolerances.
The bearings are precision fit as are the bucket lifter shims, dozens of optional sizes.
Study your FSM you will see all the variables.
Old Jan 5, 2007 | 08:48 AM
HoldThisForMe
All I really need is something like a gasket kit OEM... Bearing kit OEM... But i guess i could buy each seperate... just a PITA to me
Old Jan 5, 2007 | 08:52 AM
Eazzy's Avatar
Eazzy
Gasket set can be had*---But as stated, this is not like a Chevy where u can just get a set of Clevelite brgs and expect them to work
* I would think ?
Old Jan 5, 2007 | 10:44 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Give me a call if you need anything.
Engine Overhaul Gasket Kit
Rear Main Seal
Cosworth main and rod bearing sets (single size fit)
Thrust Washers (4 of them...two if each type)
Old Jan 24, 2009 | 11:30 AM
LSX-PWR's Avatar
LSX-PWR
I am looking to do the same.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
