Engine shuts off while i'm driving
Old Mar 21, 2007 | 10:12 AM
prpillai's Avatar
prpillai
Default Engine shuts off while i'm driving
Guys, this is my first post on the forum and I tried to search and PM for help.
Car - 2005 SS 350z 35th Ann, no mods yet.
My Z, keeps shutting off while i'm driving. This has happened 3 times in less than 24 hour span. I will be driving and the car will shut off, steering and brakes lock up. I restart the car and everything works and i'm rolling again.
I took it to the dealer and they say there is nothing wrong. I even allowed the tech to drive it home and asked him to drive "spirited". I would never do that to my baby if I wasn't worried about her.
Any help or advice for those Nissan "mechanics" would be greatly appreciated. Thanks.
pat
Old Mar 21, 2007 | 10:15 AM
PWSHHOCKEY44's Avatar
PWSHHOCKEY44
I have 6MT and mine shuts off shifting into 5th at high speeds. Could one of your gears be stiff like mine causing mis shift?
Old Mar 21, 2007 | 10:17 AM
1FlyZ's Avatar
1FlyZ
Maybe its the idle? when you are inbetween shifts maybe the idle gets too low and shuts off??
Old Mar 21, 2007 | 10:19 AM
prpillai's Avatar
prpillai
I dont remember the exact gears i've been when the engine cut off, but I was never in 6th.
Also, the last time its shut off I tried to rev it past 4k in 3rd gear. The revs hit at wall at 3800 and car shut off. I tried to recreate that problem, no luck.
Man I am really at a loss and don't want to be in a bad position the next time this happens.
Old Mar 21, 2007 | 10:25 AM
PWSHHOCKEY44
Try resetting your rev limiter on your digital speedometer display, maybe thats set at 3800-4000.
Old Mar 21, 2007 | 10:33 AM
SGP_Racing's Avatar
SGP_Racing
Default I know that you said you have no mods but---->>>>
You do not by any chance have a larger wheel upgrade do you?
-Mark
pat
Old Mar 21, 2007 | 10:45 AM
prpillai's Avatar
prpillai
I still have the same stock wheels that come with the 35th. I thought it was the VDC cutting off the engine due to excess wheel spin, ****ty stock tires, but I was assured that is not possible. Also, it would explain the steering or brake lock.
About the rev-limiter, I haven't tried that but I thought that didn't have link to the engine?
Old Mar 21, 2007 | 10:52 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
.........that's not a rev limiter. That's the shift light indicator.
PRPILLAI: you are not shifting into neutral at high speeds are you?
Old Mar 21, 2007 | 11:02 AM
prpillai's Avatar
prpillai
looking back at it, i did once. i had to merge over two lanes quickly, got up to bout 55 in 3rd gear, then shifted into neutral to stop at the light. the car only stalled after i put into gear and went about 50 feet after the light.
i know all of this might not making any sense. I do appreciate everyones help!
Old Mar 21, 2007 | 11:06 AM
Jay'Z's Avatar
Jay'Z
THATS YOUR PROBLEM......... Dont throw it in neutral.. Just slow down and take it out of gear when your almost at a stop.. Otherwise without a reflash your car revs will drop to zero and car will cut off.. Its simple.. Reflash and keep throwing it in nuetral(reflash will keep your idle up at nuetral).. Or no reflash and slow down in gear......
Old Mar 21, 2007 | 11:09 AM
I1DER's Avatar
I1DER
This may be far fetched, but the owner's manual does say that the engine can turn off sometimes when going past an electronic metering device(like on some toll booths)...I guess it affects the electronic code in the key. It may not be the problem, but a clue to what is happening.
SGP_Racing's Avatar
SGP_Racing
Default The VDC is HIGHLY possible & most likely the issue..
I have seen it here before even on new vehicles with no suspension or wheel changes. One guy showed up here, could turn his wheel all the way to the right, kick his front tire & the car would die or go into limp mode...
-Mark
Old Mar 21, 2007 | 11:13 AM
prpillai's Avatar
prpillai
i usually dont throw it in neutral. the other two time the car shut off i was in gear.
i read up on electronic meeting devices cutting power, but I wasn't near any toll booths or devices that I could see.
i'm getting the car back this evenning, dealership can't do a thing. I'm gonna ask them to reflash the ECU and double check the sensors. It all I can think of at this point.
Old Mar 21, 2007 | 11:14 AM
prpillai's Avatar
prpillai
Old Mar 21, 2007 | 11:16 AM
prpillai's Avatar
prpillai
-Mark
the guys at nissan keep saying that the vdc can't cut the engine off. that's the first thing i thought of, those ****ty tires. i'm getting AVON's put on this afternoon.
Old Mar 21, 2007 | 11:21 AM
Jay'Z's Avatar
Jay'Z
If it happens in gear that is pretty wierd.. Anyways disconnect the batter for a few hours to reset the ecu.. Stomp the brakes a few times and the accelerator.. Connect the battery and tell me how it reacts then.. Also, if you dont want to disconnect the battery just do the technosquare ecu reset..
http://www.technosquareinc.com/350reset.htm
What does your car idle at?????????
I had a problem just like this.. I would throw it in neutral and it would die........ After my reflash from Uprev.. It has never done it again.. ever....... Knock on wood...
I also made it a habit to slow down in gear..
Old Mar 21, 2007 | 11:24 AM
prpillai's Avatar
prpillai
thanks man for the link. my z idles at or about 750 rpm.
Old Mar 21, 2007 | 11:25 AM
Jay'Z's Avatar
Jay'Z
-Mark
Hey Mark, you should be resting up... You need a break.. Your gonna age like I did in Iraq.. 1 year aged me 3 years there.. (also got that from a war study lol)..
Old Mar 21, 2007 | 11:35 AM
Jay'Z's Avatar
Jay'Z
Your idle is too low.. That is the problem.. Try the ecu reset and then if that doesnt work you have to pull your ecu to get it reflashed!! Or you will have that problem till.. Forever..
My idle is at 950 now.. Its perfect!
Old Mar 21, 2007 | 11:47 AM
prpillai's Avatar
prpillai
I'm going to reset the ECU as suggested. Thanks guys, you're all better than Nissan techs any day! Much appreciated.
