Finally a lightweight battery...
Old Jun 13, 2007 | 09:28 PM
97supratt's Avatar
97supratt
Thumbs up Finally a lightweight battery...
I got the odyssey battery from Alex (Lex350) and this thing is wonderful. It's very small and light.
I have one question though. For the guys who run this battery, do you guys have the charger also or do you run without it?
Lastly, did you make your own battery tie down kit or did you buy a expensive one?
Here are the pics...
Old Jun 13, 2007 | 09:34 PM
aren21's Avatar
aren21
damn dude how much does that thing weigh???
Old Jun 13, 2007 | 09:42 PM
BaTMan_4's Avatar
BaTMan_4
^ +1 on weight?? that thing is tiny
97supratt's Avatar
97supratt
It says 12.6lbs on it but I think its less.
Old Jun 13, 2007 | 09:53 PM
aren21's Avatar
aren21
do you think the weight savings is the worth the price? Im assuming its pretty expensive...
Old Jun 13, 2007 | 09:58 PM
SuperBlack350z's Avatar
SuperBlack350z
lol, yeah it's 13 lbs. They don't state it to make false assumtions. Those oddessey batteries are great and is the new trend for performance only enthusiasts.
Old Jun 13, 2007 | 10:07 PM
97supratt's Avatar
97supratt
Brand new they have em for 120. I bought this thing used.
Old Jun 13, 2007 | 10:13 PM
97supratt's Avatar
97supratt
Here's a link to a site which sells it for a great price.
http://www.gotbatteries.com/items.as...SL141/37L141S5
Old Jun 13, 2007 | 10:37 PM
aren21's Avatar
aren21
hey thats a pretty decent price..thought it would cost more.
Old Jun 14, 2007 | 12:33 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I just bought the Braille CF 2015 w/ charger myself. What do you think of the Odyssey? Why did you get the Odyssey vs Braille? Just curious.
Old Jun 14, 2007 | 07:22 AM
97supratt's Avatar
97supratt
The easiest answer is price. To me it's just a battery, plus i've heard of many race teams who use odyssey so it must work.
Did you get a custom tie down?
Old Jun 14, 2007 | 07:33 AM
97supratt's Avatar
97supratt
I found this thing on ebay, i'm wondering if I can make a tie down that would be NHRA legal.
http://cgi.ebay.com/ebaymotors/Batte...spagenameZWDVW
Old Jun 14, 2007 | 07:36 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Understandable. The CF wrapped Braille is $50 more but I plan to move it to the trunk area in the future. Maybe than I get the Braille mount. $50 for CF ok... $80 for a mount.... not right now at least.
Old Jun 14, 2007 | 08:25 AM
shushikiary's Avatar
shushikiary
LOL @ 185 CCA and only 12 Amper Hours... but then again it is a performance only light weight battery...
Though it is nice to see 10.8 lbs on the 545, and 400 cycles at 80% discharge at 77 deg F.
I use the hawker genesis series batteries for my electric go kart, but they are 42 amper hour and weigh alot more... but when you're pulling 500 amps for a 20 horse motor you need alot more umph.. lol (it does 80 mph btw).
http://www.gotbatteries.com/items.as...P/all/37L140S1
4 of those in series for 48 volts.
Old Jun 14, 2007 | 08:44 AM
97supratt's Avatar
97supratt
I have no clue what you said. lol
Old Jun 14, 2007 | 09:01 AM
Ghost 350z's Avatar
Ghost 350z
+1
Old Jun 14, 2007 | 09:10 AM
linknpark15's Avatar
linknpark15
how much does the stock battery weigh?
Old Jun 14, 2007 | 10:48 AM
gothchick's Avatar
gothchick
Lol~ Made my head hurt too. :-)
Me likey this battery.
Old Jun 14, 2007 | 10:49 AM
97supratt's Avatar
97supratt
40-45lbs I think.
Old Jun 14, 2007 | 11:26 AM
shushikiary
I looked at the PDF data sheet for the battery that they gave. It said that at 0 degree's the battery would only put out 185 amps (cold cranking amps - CCA) AKA it wouldnt do a very good job of starting your car if it was 0 degree's outside, but that's not the point, it's a performance only battery.
An amper hour is the measure of how much energy is in the battery. 1 amper hour means the battery will output 1 amp for 1 hour. They do this because volts*amps = watts however the voltage of the battery goes down as you draw current from it, so they measure it in amper hours instead of just watts usually, however the PDF file does have the averaged power output over a steady current draw from it's spec voltage to 10.2 volts.
- translation: 12 amper hours means the battery doesnt hold much energy, but that's partly due to it's weight, less weight = less energy storage when it comes to batteries. On average I'd say that most stock 12v car batteries range from 40-60 amper hours. This one wouldnt run your radio or ignition long, but again that's not the point, it's for weight reduction for performance. I was just laughing at it's specs in those area's. But for the weight it's hard to beat.
The other comments were just about how I chose a similar but larger battery to power an electric go kart I made that has a 20 hp electric motor on it will do 80 mph (actually I dont know how fast it will go, speedo max's out at 76.9 mph and it will definitely go past that)
