Direct Injection?
I was reading through a window sticker when I went to pick my car up about a week ago and it said "Nissan Direct Injection System" in the engine description section. I pulled my sticker when I got home, sure enough, says the same thing.
I know the advantages of direct injection (better charge cooling, better metering and atomization, etc.) and know that it is ESPECIALLY advantageous for a turbo car. Understanding the HR will be getting turbo-ed for the GTR, knowing that they increased the bottom end strength not only in the block, but in the shear area available to the crank bearings, lengthening connection rods, etc., all things that would reduce crank shaft vibrations and forces - is the HR out in the 07 in a testing phase for the GTR?
Why would DI be put in the motor if not for turbo apps, and if its to test for the GTR would these improvements not indicate that the motor can take much more boost (nitrous also) than the DE's?
Just curious, maybe all the VQ's have it and I just never noticed, but I thought it was cool and it made me happy knowing I had one
Originally Posted by Tac-M
read it again... it is Direct Ignition ! that has been on nissans since 2000?
For as much as I've seen them copying BMW's technologies (and usually improving weaknesses, example variable valve lift) I'm surprised to see them as a pioneering company.
I wish Nissan would go with direct injection, but then would our engine sound like a new Audi FSI 2.0T engine? (if you never heard it, it's like a diesel
US fuel quality [sulfur%] is still marginal for DI if life much beyond warranty is a concern.
Toyota is attacking the problem with a simultaneous use of conventional and DI [2 injectors per cylinder one of each].
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Subarism
East Canada
Sep 23, 2015 06:23 PM
