Help
Old Sep 3, 2007 | 08:29 PM
rhynesimpson's Avatar
rhynesimpson
Default Help
I love my 350Z. I have since the first time I drove it, but sadly it seems I have almost got bored with it..and was wanting some nice 'not too pricey' (such as turbo) ways to speed it up a little. Name some things I could use that would help me out with some speed.
(Currently only engine work = popcharger) =p
Old Sep 3, 2007 | 08:33 PM
Varis air duck.
Old Sep 3, 2007 | 08:43 PM
Escobar's Avatar
Escobar
Q: What is a plenum?
A: On the 350z / G35, your plenum is the aluminum intake manifold that sits right in the upper middle of your engine bay. To locate it, find the air intake box, follow the tube to the throttle body, and you will see that the plenum is connected to the throttle body. The plenum consists of both the "upper plenum" which you can see plainly in your engine bay, and a "lower plenum" which is not visible in your engine bay. You cannot see it because your lower plenum sits beneath the "upper plenum". If you remove your upper plenum to install a spacer for example, you will see the "lower plenum," also known as a "lower collector". The lower plenum consists of 6 tubes or "runners" that guide the air from your plenum into each cylinder. They may not look that fancy, but in fact, the precise length of these tubes has a significant impact on horsepower and torque.
Q: What is a plenum spacer?
A: Several companies make a "spacer" which rests between your lower plenum and upper plenum, to increase plenum volume and reduce restriction from within the plenum. For example, Motordyne engineering's 5/16" spacer, or AAM's angled spacer. Increasing plenum volume typically has the effect of increasing horsepower. However, if you increase the volume too much, you will start to lose throttle response. Plenum design is a crucial aspect of engine design -- companies that make spacers are simply trying to get the most function out of the plenum.
Q: What is better, a plenum spacer, or a complete aftermarket plenum?
A: Some people swear by aftermarket plenums (i.e. crawford, kinetix), but for all intents and purposes, they accomplish the same exact thing as adding a spacer. So most people would tell you to choose whichever one is cheapest, which is usually the spacer.
Q: What is the difference between the REV-UP (300hp) and the NON-REVUP (287hp) Motor? Which one do I have?
A: Rev-up Motor has higher peak HP, lower peak torque, and a higher redline (7000RPM)
Non-rev-up Motor has lower peak HP, higher peak torque, and a lower redline (6600RPM)
Rev-Up Motor has variable Intake and Exhaust timing.
Non-Revup Motor ONLY has variable Intake timing.
You can tell which one you have by looking at your redline on your tachometer.
Q: What is a MREV, and MREV2? Which one do I need for my rev-up (300hp) or non-rev-up 287hp motor?
For 2003 - 2006 350Z's / G35's, Nissan has designed two different types of lower collector:
REV-UP lower collector from the 300hp motor = shorter runners which are tuned for lower peak torque, but higher peak horsepower.
NON-REV-UP lower collector from the 287hp motor = longer runners which are tuned for higher peak torque, but lower peak horsepower.
MREV = same exact thing as the non-rev-up lower collector, but Motordyne Enginering has given it a name.
MREV2 = Using the MREV as a starting material, this is a CUSTOM lower plenum that is sold by Motordyne Engineering. It has been precisely machined to remove aluminum from critical locations on the MREV. In other words, it is like a much improved version of the MREV which reduces restriction and improves HP / TQ.
If you have a non-revup motor (6600RPM redline), your best bang for your buck is to get the 5/16" spacer. The 5/16" spacer makes the most HP for the money. OR, you may choose to get the MREV2. By replacing your stock lower collector (MREV) with this better flowing version, you will make better "area under the curve" on the dyno in terms of HP gain. My opinion is that you should choose one or the other -- either MREV2 OR 5/16" spacer. If you get both, the HP gain will exhibit "diminishing returns", meaning you will spend a lot more money to make not much extra HP. So, usually the recommended option for the non-revup guys is to get the 5/16" spacer.
If you are a rev-up owner (7000RPM redline), you will basically only benefit from getting BOTH a 5/16" spacer and the MREV2. If you get the MREV2 only, your mid-range torque will increase but your maximum HP will drop off severely. If you only get the 5/16" spacer, you will not see a benefit. Several dynos have proven that for the rev-up motor, you basically need both the spacer and the MREV2, which will make a lot of midrange torque, without sacrificing too much peak HP.
For more information, search through the Intake Exhaust forum and read several old threads on the subject matter.
Q: What is a reflash?
A: Companies such as Technosquare or AAM (Altered Atmosphere) will reprogram your ECU (engine control unit) to better adapt to mods such as intake, plenum spacer, exhaust, etc. Additionally, a reflash (such as Technosquare) can increase the rev limiter to allow for a higher redline. The stock ECU is well known for, well, sucking. It does not adapt well to mods or optimize air/fuel ratio to give the most power. Some mods can actually lose power with the stock ECU if you do not have the right tune. A reflash will basically help your stock ECU make the right adjustments to make the most power with your mods.
Q: I got an intake, exhaust, headers, plenum spacer, and/or other mods. Do I need a reflash / tune?
A: Most people *will* benefit from either a reflash or tuning, even if you are lightly modded. THE BEST OPTION IS TO FINISH ALL OF YOUR BOLT-ON MODS BEFORE GETTING TUNED!!
The best way to get a tune is to purchase an engine management system and take it to a reputable tuner. There are several options. The most popular option is the TurboXS UTEC. The UTEC seems to have the most powerful combination of features for the money. The Greddy Emanage Ultimate, for example, is another good option for air/fuel tuning, but it does not have good over timing. Your best bang for your buck when tuning is usually going to be a reflash, but reflashes do not have nearly the customizability as the UTEC.
Q: I want to know which exhaust sounds the best. Does anyone have sound clips of Stillen, Borla, HKS, Injen... etc?
A: First off, sound clips almost never do an exhaust justice. Most people lack good recording equipment, some people even record sound clips using their cell phone. Do not trust any sound clips you hear online. The BEST way to figure out which exhaust sounds the "BEST" is to hear it in person. Go to a local meet and ask nicely for people to drive you around with the windows down. Some people will rev the engine while parked to give you the idea. That is all well and good, but note that exhaust systems sound a little different while UNDER LOAD (driving around).
Q: Okay, but which exhaust system is the LOUDEST, MEANEST sounding exhaust?
A: RSR, Topspeed, or any clones of these systems.
Old Sep 3, 2007 | 08:44 PM
Escobar's Avatar
Escobar
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions.html
Old Sep 3, 2007 | 08:48 PM
Escobar's Avatar
Escobar
spacer, full exhaust, re-flash:
check this out, https://my350z.com/forum/engine-and-drivetrain/298741-6-free-and-cheap-ways-to-add-a-little-more-hp.html
Next time you use the search function
Old Sep 3, 2007 | 08:50 PM
stalarman@yahoo's Avatar
stalarman@yahoo
Get some test pipes on the used vendor site, adds a deeper growl and good to have. think 5-7 hp ish. nevertheless, something to get you out of boredom.
Old Sep 3, 2007 | 10:17 PM
I am with Z's Avatar
I am with Z
Angry
Originally Posted by davidv
Varis air duck.
ha ha you made me laugh, you always have something to say, in a direct or indirect manner.
I don't understand it though I've notice these type of post keep popping up more lately, whats the deal.
Old Sep 3, 2007 | 10:23 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
It's even funnier that you dont understand.
Old Sep 3, 2007 | 10:50 PM
rhynesimpson
Well I guess I wouldn't say I am bored with the Z..it's just that when I first got it I was so proud of the speed..and still am..I guess im just ready for more!
Old Sep 3, 2007 | 11:59 PM
AlmostJesus's Avatar
AlmostJesus
Yeah I kind of get that feeling too. Like, the Z is really fast...I love it...but I need more speed. The "shoot back in your seat" feeling isn't as exciting anymore...I want to go through my seat and out the back of my car. I guess I just have to wait until I finish paying it off before I start adding mods...but one thing I do want is my navi installed.
Old Sep 4, 2007 | 12:07 AM
henry j's Avatar
henry j
lollll poor guy ima give a hint....only has shortram intake...................
Old Sep 4, 2007 | 01:34 PM
I am with Z
now idwin you were not telling me that were you? I have one, and installed 5 of them, I got it down .
