pre-mods for turbo
Old Sep 8, 2007 | 06:41 PM
350Zimo's Avatar
350Zimo
Default pre-mods for turbo
well, i want to begin modifing my Z, and i will eventually boost it, so what i have been tring to figure out is what mods should i install so i would not have to upgrade, after the car is turbo'd, for inctanse, if i get exhaust 2,25 inch would it be compatible with a turbo, or 2.5 be better, people say 3 inch is the best, but on a stock engine 3 inch would be too much of a low end power loss. therefore, any advices are accepted , thanks
Old Sep 8, 2007 | 08:10 PM
HDPDZO6's Avatar
HDPDZO6
When you plan on buying a house, what do you buy first?
If you are going to go FI, then select a kit and get that first. Then buy additional mods based on the purchased kit. Not all FI options are the same.
Old Sep 9, 2007 | 01:10 AM
Ruthless18x's Avatar
Ruthless18x
+1
Most people say they will go FI sooner or later but end up never getting close.
Old Sep 9, 2007 | 08:27 AM
Zridder19's Avatar
Zridder19
Just save enough money so that when you go to get it done, you can do it all at once, better safe than sorry. I had 1/2 plenum spacer, and 3" single exhaust b/c I knew I was going to go with a TN single turbo. Consider your options and what you want/ can afford then go from there.
Old Sep 9, 2007 | 08:45 AM
350Zimo's Avatar
350Zimo
yeah, i agree with you, i did some additional research , and it's got to be done correctly , and at once. so , saving money is the key word. thanks to everybody .
Old Sep 9, 2007 | 09:32 AM
i8acobra's Avatar
i8acobra
In preparation for FI, I got a Koyo radiator, Nismo t-stat, Samco hoses, Turbo XS UTEC and MAP sensor, AEM wideband, JWT clutch and fly, HFC's, Borla TD cat-back, Redline oils (engine, tranny, diff), Apex-i turbo timer, wider rims and a radiator diverter plate. Other mods I plan on getting... 650cc injectors, oil pan spacer, return fuel system, swaybars, springs, shocks, 255 lph fuel pump, Cometic head gaskets and ARP head studs (will be done when I install the JWT S7 cams I already have), oil cooler and Autometer boost, oil temp, and coolant temp gauges.
Old Sep 9, 2007 | 03:46 PM
350Zimo's Avatar
350Zimo
so, from what you've said Borla TD can be installed prior to the turbo, and it is going to have a turbo suitable 2.25 inch piping diameter???
Old Sep 9, 2007 | 05:48 PM
meatbag's Avatar
meatbag
Get a built block
Old Sep 9, 2007 | 07:21 PM
350Zimo's Avatar
350Zimo
I've got the HR, so i dont even know what the stock block can do. I know that there arenot too many options when i come to mods for the 07', but i meant mainly exhaust, test pipes, gears, and things that will be compatible with a turbo , because i am planning to get one as soon as it is released on the marked.
bcoffee20
Nov 19, 2015 06:39 PM
