Single Turbo or Twin Turbo ?
Old Jun 3, 2003 | 02:29 PM
1320AutoSports's Avatar
1320AutoSports
It all depends on the setup.
Wouldnt you figure that is why a lot of TT Supra people go a huge single turbo.. TONS of variations here..
Old Jun 3, 2003 | 02:50 PM
demon's Avatar
demon
The reason we do this is primarily due to simplicity and the fact there is almost no benefit to a twin setup over a well matched single. Some people run the HKS 2835 twins, but they are far laggier than a single producing the same power.
Old Jun 4, 2003 | 12:30 AM
joeshow750's Avatar
joeshow750
There is no way of simply "turning off" turbos - the only way would be to drive with less throttle or to stay out of certain rpm's at full throttle. Unfortunately the complexity of creating a sequential system is immense and you are unlikely to see any aftermarket option.
True, but if you have a big enough wastegate you can very little or possibly no boost at all throughout the rpm range.
Edit: One thing that should be discussed is mechanical effeciency. TT's have a lower rating due to the two shafts (2 turbos vs. 1, 2 sets of journal and thrust bearings) and therefore more friction...even though friction is pretty slight with modern day ball bearing turbos, at 150,000 rpms a piece there's going to be some loss.
bcoffee20
Nov 19, 2015 06:39 PM
