Need advice on Clutch & Flywheel
Old Oct 19, 2007 | 10:31 PM
acerys's Avatar
acerys
Default Need advice on Clutch & Flywheel
Clutch is gone. I am planning to get both stock clutch kit and flywheel replaced with RPS flywheel and JWT clutch kit, but I do not know if they actually will work togather. Anyone knows that? Where I can get a good deal?
Old Oct 20, 2007 | 06:24 AM
page04Z's Avatar
page04Z
There are good buys on clutch/flywheel combo's in the vendor section in the marketplace
Old Oct 20, 2007 | 06:27 AM
IIQuickSilverII's Avatar
IIQuickSilverII
i dont think it works....
rps fly not compatible with jwt clutch
what woudl work...and IMO is a much better setup is the RPs max(6puck) Clutch and JWT flywheel...or jsut get all RPS
Old Oct 20, 2007 | 09:13 AM
acerys's Avatar
acerys
I have heard good feedback on RPS flywheel. My G only has 250whp,I do not need the clutch that can hold a lot of power,just slightly better than stock one is enough for me, but I do need a quite and light-weight flywheel.
Old Oct 20, 2007 | 01:52 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Act
Old Oct 20, 2007 | 01:53 PM
acerys's Avatar
acerys
Do you mean ACT CLUTCH OR COMBO?
Old Oct 20, 2007 | 01:55 PM
Z1 Performance
Former Sponsor
we use and recommend the ACT clutch and their flywheel as well - to date, the quietest flywheel we've used
Old Oct 20, 2007 | 02:05 PM
Axel's Avatar
Axel
Are you staying with the stock pressure plate? Or are you going with the ACT clutch/pressure plate combo as well?
Old Oct 20, 2007 | 02:17 PM
Z1 Performance
Former Sponsor
there wouldn't really be much point to using a stock pressure plate with an aftermarket disk
We have the combos listed on our site - I'd personally go for the ACT Heavy Duty clutch + Prolight flywheel - holds gobs of torque, very easy to drive, one piece billet chromoly flywheel. The clutch includes the throw out bearing and uses a full radius, organic disk, so it is easy to drive, and requires no heat to be built up in order for it to hold full torque
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1149
Old Oct 20, 2007 | 08:34 PM
acerys's Avatar
acerys
Still have no idea which combo I should get. I personally drove my friend's 350Z with JWT combo,no chattering at all,but many people did tell me the combo does chatter.Damn,I got confused. How about Jun's flywheel?
Old Oct 21, 2007 | 05:59 AM
Z1 Performance
Former Sponsor
chatter means different things to different people
to some, chatter is the noise the flwheel makes, especially during clutch engagement from idle to about 2500 rpm. In this regard, the JWT is among the loudest flywheels out there.
Others refer to chatter as the amount of "juddering" the car does when engaging first gear from a dead stop. If this is what you are referring to, then no, the JWT setup does not exhibit this trait
Old Oct 21, 2007 | 06:50 AM
IIQuickSilverII
i like act... but for the clutch....at this price range... RPS stree n' the 6-puck still best... for flywheels...JWT is fine...IMO...rps fly is pretty good too
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
