swapping rear differentials...
Old Nov 18, 2007 | 10:24 PM
AGent_SaMo's Avatar
AGent_SaMo
Default swapping rear differentials...
ok heres the deal. I have a base model 2005 350z and I also have a 2007 G35S. Now, i want to swap the rear diffs because the G has a VLSD and the Z does not. Will it directly bolt up? Is this swap possible or am i going to run into obstacles?
-Sam
Old Nov 18, 2007 | 10:28 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
-Sam
Robbing Peter to pay Paul?
You own both cars in question?
Old Nov 18, 2007 | 10:37 PM
AGent_SaMo's Avatar
AGent_SaMo
yes i do
Old Nov 19, 2007 | 07:48 AM
helldorado's Avatar
helldorado
The FD ratios are different. 2007 G35 sedan uses the 3.692 and your base Z uses the 3.538. So there's more to it than just swapping for the VLSD.
Old Nov 19, 2007 | 08:54 AM
AGent_SaMo's Avatar
AGent_SaMo
i wanted to swap out the whole pumpkin becuase i have a 4.0 final drive going in anyways. So my question is...would the pumpkins swap out without any problems?
-Sam
Old Nov 19, 2007 | 11:39 AM
helldorado's Avatar
helldorado
The pumpkins should swap, but its no gaurantee. The 2007 G35 sedan is an updated platform, unlike the 2007 Z. I don't think anybody has tried that swap yet.
If you're going to swap in the higher gears, why bother swapping pumpkins and just rebuild your Z's pumpkin with a better diff at the same time? The effort you'll go through just to get the VLSD from the G35, while making that car slower, I just don't see the logic in it.
Old Nov 19, 2007 | 02:17 PM
Lawn Dart's Avatar
Lawn Dart
Better gas mileage for the G and a better gear ratio, plus a VLSD for the Z. Makes sense to me.
Old Nov 21, 2007 | 06:22 PM
n1sm0r's Avatar
n1sm0r
Yes, they are compatible.
