AMS Lightweight pulley sets
Originally Posted by Dave B
Also, find one real racing team that is running UDPs or lightened pullies on their engines. Do you see them on factory Nissan race cars? Hell no, you see fluidamper units. Think about that for a second.
Originally Posted by seZy350
so what you guys are saying this should be a straightforward install? no adjustments or burping of the ps of that sort? ive planned to get this kit and if its a straightforward install i might just do it myself.
yeah, pretty much straight forward indeed. i've had UR pulley(underdrive) on my 03 since 04, there is definitely a noticeable gain in throttle response. It put a smile on my face after the install. You will need a 22" breaker bar to loosen the main crank bolt.
Originally Posted by Hoooper
i have a 13 second 2002 max, i know pretty well what im looking at, considering every engine mod ive done was done myself
Originally Posted by Reality350
I believe its the same as stock, just lighter in weight
Dave B,
These are not UDP, they are LWP.
Good right up though.
Dave B,
Okay, point taken. How then does someone incorrectly install an aftermarket pulley without having the entire motor fail in the process? You alluded that I had misinstalled my UR UDP on my old VQ30 hence the reason I saw no performance benefit. I'd like to know how that's possible seeing that the pulley slides on only way, I replaced the crank seal, the timing ring was fine, and the belts were set to the correct deflection. I had that pulley on for nearly 2 years if I remember correctly. How could of my VQ lasted over 20K miles, 40 1/4 mile passes, and 8 dynos with a misinstalled pulley?
just the absolute smallest little imperfection of the mounting surface (grime, dirt) will cause a slight vibration that wont ruin anything but would be annoying
for the vibration that you had (explained), you had to either have a bad pulley or something on the mounting surface. a correctly formed and correctly installed pulley will not shake like that
its commonly known that DAVEB is against lightweight/UDPs. at this point, ive heard his banter enough that i dont even read it
It is commonly known that he is against about every damn single mod on the G35 or Z that has been proven in the past to work but since he doesn't own one or never has he rather just argue to no end with no experience behind his belt or facts that they don't work. Everyone is sick of his bickering on the G forums, and now he is here.
Technically Daveb is right in theory. The stock pulley is specifically designed to dampen frequencies that can harm the crank. His explanations are accurate; again in theory.
However, the fact remains that plenty of people have properly installed lightweight pulleys with proper pressed steel inserts without breaking their crank or blowing up their engine for long periods of time. This fact is even highlighted by Dave, furthering his credibility on the matter imo.
So do you believe the theory or the reality of its use?
I think if you are racing or boosted, fluidampr is a must, if you are NA and DD then I guess it's a toss up. Believe what you want to believe. But I think there is a definite track record of properly constructed lightweight pulleys for the vq35 never destroying any cranks or engines. As far as advantages are concerned, there's no doubt there is a gain in throttle response, but as far as actual gains or helping a 1/4 mile time or the like, well that's up in the air imo--I haven't seen proven results on this board in the form of dynos or lowered 1/4 mile times--but that didn't stop me from buying a set.
I believe Daveb disputes the claimed gains and advantages of the lightweight pulleys, especially in light of the possible risks of not having any sort of dampening properties in a lightweight crank pulley. There's nothing wrong with thinking that way. He's entitled to his opinion.
I guess I just chose to go ahead and run the lightweight, but stock diameter UR pulleys-no problems as of yet. But the fluidampr is going on if/when I go boost.
after installing these.. underneath the hood motor seems to be alot louder.. is this normal?
Originally Posted by Z1 Performance
yes, you'll hear the accessories a bit more with an aftermarket pulley, with either a std diameter or under driven one
Thank you.
truth be told its not noticeable at all unless you are standing over the engine bay with the hood up
I will most likely get the crew from AMS to install my LWP's, so if its to noisey I will just b|tch them out
....Vuk, I KEED!
