"paddle" shifter on 5AT
Old Jun 6, 2003 | 02:20 PM
N74DV's Avatar
N74DV
Default "paddle" shifter on 5AT
I'm thinking of working on a mod for my Touring 5AT.
Steering wheel paddle shiffter. I'm going to see about putting some momentary buttons on the backside of the side spokes of the steering wheel. One for upshift and one for downshift.
I'm assuming I can tap into the existing switches in the shifter for the manual mode... Since the steering wheel turns I can't just run wire up to the wheel for the switches.... I'll have to work on some form of brushes or something.....
I just think it'd be slick to shift in manual mode without taking hands off the wheel.
Old Jun 6, 2003 | 04:38 PM
menehune's Avatar
menehune
Keep us informed on how the project goes.
Old Jun 6, 2003 | 05:16 PM
N74DV's Avatar
N74DV
I pulled the trim panels to gain access to the shifter... This is gonna be easy on the shifter side of it... there are two micro switches that are used to shift up and down. I just need to tap into these wires...
the hard part is now getting the momentary switches into the back side of the steering wheel.
now, I gotta figure how to get the stering wheel off....
Old Jun 6, 2003 | 05:30 PM
thackattk's Avatar
thackattk
Best idea I've heard in a while. Keep us posted!
Old Jun 6, 2003 | 05:56 PM
03tour's Avatar
03tour
NICE......ive had this idea running around in my head for a while.... too lazy to look for a place start...defintely keep us posted!!
Old Jun 6, 2003 | 09:05 PM
ajk4's Avatar
ajk4
N74DV do you have a fsm? that would be extremly helpful in removing the steering wheel.
Old Jun 7, 2003 | 09:02 AM
N74DV's Avatar
N74DV
OK... here's probably how this is gonna work... It's going to be too difficult to work up some contact brushes for the switches in the wheel, so I have another idea....
I'm going to use a 2 channel rolling code UHF transmitter/reciever.
The transmitter (very small) will be placed in the steering wheel and two momentary switches will be run to it...
The receiver (also small) will be placed in the center console... the receiver has two relays built in, so I just need to tap the shifter microswitch wires into it....
What's nice is it uses rolling codes, so if you happened to pull up next to another Z with the same setup(not likely) he won't be shifting your Z
here's a pic of the setup... the transmitter will be disassembled and only the pc board used.
Old Jun 7, 2003 | 09:37 AM
rouxeny's Avatar
rouxeny
Interesting idea. Keep us informed.
Old Jun 7, 2003 | 12:24 PM
r34 racer's Avatar
r34 racer
have you thought of a failsafe/backup idea if you are in the middle of a race and something goes wrong with the wires in a race? Im sure you could always just reach down and shift, but its good to have something to fall back on. Also, what happens if you press one of those buttons when the tranny is in auto?
Old Jun 7, 2003 | 07:38 PM
give_me_7's Avatar
give_me_7
Default Call this guy...
http://www.bmw-paddleshift-retro.com/
He will be able to get you to where you need to be. You have already figured out the hard part. But, it is not going to be cheap. He will help you make a kit for retailing.
Old Jun 16, 2003 | 06:43 PM
N74DV's Avatar
N74DV
got it working.... it's sweet!
One button on the back side of the steering wheel for upshift and one on the other spoke for downshift... They are activated by index finger.
There is about a .1 second delay between pushing the button and the relay closing the circuit, but it's not bad.
I used a 4 channel remote system and I still have 2 unused channels.... hmmmm.....
Old Jun 17, 2003 | 09:42 AM
03tour's Avatar
03tour
N74DV....Where did you get the transmitter/reciever and how did you mount the transmitter on the wheel....tell me what i need to know to do this my self if ya dont mind...ive been waiting for this mod from somebody......also is the .1 second on top of the normal delay of manual shifting?....thanks a million.
Old Jun 17, 2003 | 10:37 AM
N74DV's Avatar
N74DV
I got it here:
http://electronickits.com/kit/complete/elec/ck1616.htm
You can buy the unit assembled or save a few $$ and build it yourself.... I built mine.
The slight delay is the time from pushing the button until the relay clicks the tiptronic circuit closed... it's very minimal so you have to plan your shifts ahead by about 500 rpm.
Old Jun 17, 2003 | 11:34 AM
03tour's Avatar
03tour
apex locator
Oct 6, 2015 05:58 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
devaraj
Nov 9, 2002 11:38 PM
