Squeaking Clutch Pedal
Old Feb 20, 2008 | 04:08 PM
EricChan's Avatar
EricChan
Banned for NON PAYMENT
Default Squeaking Clutch Pedal
Hey sorry in advance if this was discussed, if anyone can point me to the thread id be grateful..
anyways, about a month ago I had service on my 03 track model, and I started getting this annoying squeak when i push down on the pedal. Anybody else have the same problem or anyone got a fix for it? Anyway the sound only happens when i push down on the clutch and its fine when it comes up. It sounds like a bad door hinge and is starting to get embarassing.
Old Feb 20, 2008 | 04:31 PM
pmohr's Avatar
pmohr
https://my350z.com/forum/search.php?searchid=5511674
Old Feb 21, 2008 | 11:07 PM
EricChan's Avatar
EricChan
^^ link doesn't work. Any other Ideas.
Old Feb 21, 2008 | 11:16 PM
350x04's Avatar
350x04
im having the same problem
Old Feb 22, 2008 | 01:31 PM
EricChan's Avatar
EricChan
TTT... anyone??
Old Feb 22, 2008 | 03:46 PM
garage-c's Avatar
garage-c
Same problem here in my '03 track. Sounds like a worn plastic bushing. I'm going to get under the dash and put some white lithium grease on all the pivot points & spring.
Old Feb 22, 2008 | 07:49 PM
undrgnd's Avatar
undrgnd
Good thinking. That's what I would have done first, before posting for help about a frigging squeak. What else do you think it could be, metal fatigue?
Old Feb 24, 2008 | 10:12 PM
EricChan's Avatar
EricChan
undrgnd .... Yes well if greasing the assembly had worked on the "frigging squeak" then i wouldn't be on here asking for help. This is a forum where we ask for information from other members who may have similar problems and learn about our cars. If you have nothing to contribute to this thread then just ignore it. end rant . .
anyways, thanks garage-c for the advice but I had already tried the same thing. The noise doesn't actually come from inside the car. Its actually Outside the car. I had already greased the entire assembly inside the car. I guess i'll just have to lift the car up next weekend or when i have time and try to figure it out. I'll post up anything i find. I read in another thread that it could be the "Thrust Bearing" wearing out. From reading the other thread it said that the entire gearbox has to be removed in order to get to that bearing to re-grease it.
Old Feb 25, 2008 | 01:42 AM
undrgnd's Avatar
undrgnd
If you had done that, maybe you should have said it up front? Anything else you tried which did not fix the issue?
What thrust bearing? In the tranny? Seriously doubt moving the clutch pedal would produce a squeak because of a bad tranny thrust bearing. Do you have an aftermarket clutch? Thrust bearings typically go because of high clutch pressures as found on performance clutches.
Old Feb 25, 2008 | 07:59 AM
EricChan's Avatar
EricChan
No aftermarket clutch, and nothing else done to try to solve the squeak but lubing all the moving parts visible. Sorry if i wasn't clear but would have thought it to be somewhat of common sense to at least try to lubricate the parts (like it was a creaking door hinge that needed lube). Also I did mention that I took it in for service for the 30k and they should have adjusted and lubed the clutch assembly among other things.
Im just trying to get to the bottom of this. When I searched through the forums all I could find was this:
and other threads that were just dead ends.
I guess I'll just have to put her up in the air this week and figure it out. Just thought somebody on here might have encountered the same problem and had a fix for it. also one more interesting thing is that it doesn't make the noise the first time you depress the clutch after you start the car, but every time after that it makes the creaking noise. Almost sounds like metal to metal thats not lubricated enough.
I'll post up if I find anything.
Old Feb 26, 2008 | 08:54 PM
maximariceboi's Avatar
maximariceboi
I recently picked up a 04 track..im having a similar problem as well. Also my car makes this rattling noise when i turn the car off. When i step on the clutch it doesn't make that noise....
Old May 5, 2008 | 03:33 AM
Eric the Ricer's Avatar
Eric the Ricer
Any updates on this? I am having the same problem, and want to get it resolved
Old May 5, 2008 | 05:06 AM
go-fast's Avatar
go-fast
sounds like the pivot ball on the clutch fork,there is a rubber boot you can remove to access it but be carefull of how much lube you throw in there!
Old May 6, 2008 | 11:49 AM
firekrave's Avatar
firekrave
I had that problem about 3 weeks ago on my 06. They (Nissan) replaced the, crap um, i think it was called throw-out bearing. Warranty work though. I dont know how much it would be without it.
Old May 6, 2008 | 11:53 AM
Rowlett's Avatar
Rowlett
Dose the sound come from outside, or in?
I had the sound come from in... fixed with lithium grease...
Now i have a squeek on the out side....
Old May 6, 2008 | 07:08 PM
j.arnaldo's Avatar
j.arnaldo
...LADIES & GENTLEMEN! YET ANOTHER Zed clunky MT thread!!! WE Auto tranny Zed owners are REJOICING ABOUT THE MONEY & TIME---besides the
hassles!!!---WE'VE SAVED OVER THE YEARS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Whoa!!!!!!
Old May 7, 2008 | 12:11 PM
Thermal1's Avatar
Thermal1
^^ Nice input. But Id rather drive a MT and have fun. AT are for:
Old May 7, 2008 | 01:35 PM
Spork's Avatar
Spork
Manuals are more fun. They're more "drivers' cars" as it give you more control over the gear, etc.
I'm having this same squeak issue, except it goes away every once-in-a-while.
It comes from the outside.
Old May 7, 2008 | 03:44 PM
CSF's Avatar
CSF
Old May 7, 2008 | 07:24 PM
6MTHavok's Avatar
6MTHavok
Same issue in a '03 G35 coupe. The squeak defintely comes from the outside of the car. It will sometimes go away after I've driven for 20+ minutes, but will come back after the car has cooled down. I get the a squeak both with pressing in and releasing the clutch.
