350Z Fuel Level Sending Unit???
Hello, I am from the UK but seem to be suffering with the same issues as this, can someone please provide me with more info, where is the sender, or what appears to be sender(s) located and how do i access them, I am driving a Jap Spec car so obv its RHD. Any info would be appreciated
There should be 2 level sensors in the rhd models also.
check the one without the glovebox first.
There are several junkyards in the UK with salvage Zs that will ship to you.
One is located under the glovebox and the other on the opposite side, same location.
Test the resistance while moving the float.
BTW do you have access to RHD models Nissan OEM part number list
Originally Posted by raycs7
JDM part numbers for the RHD models.
Like on the collision estimators guide for the feasibility of a rhd conversion.
update on my issue...
It turns out that there was a break in the wire from the sending unit in the main assembly behind the passenger seat.
I spliced a wire in and the gauge worked.
My '03 G35C had the annoying "tank won't fill past 3/4s" issue back in '04. It was still in warranty, so the dealer replaced the "fuel sender unit" (is what they called it). So, ~35k miles to 114k miles it worked. . .and now it's doing the same thing. I just got gas today and the pump clicked off letting me know the tank was full, but my gauge only reads 3/4s full again. Thanks for already doing most of the research for me! I'll check my units (since I'll probably throw in a walbro now in slow s/c install prep) and post my results.
Kuneff, did you ever get this resolved? And what part#s did you order?
bcoffee20
Nov 19, 2015 06:39 PM
