Problem with my Z upon ignition
Old Apr 3, 2008 | 11:56 PM
KJ1225's Avatar
KJ1225
Default Problem with my Z upon ignition
Hey guys, I've searched for an hour or so and can't really find a definite answer to my problem so hopefully somone can help me out here
When I start my car (03 - Track Pack) the rpm increases upon igniton(normal) then when it falls back down to idle speed it either does one of 2 things:
1 - Drops back down to 0 and stalls
2 - It drops real low and stutters a bit but rises back up to normal idle rpm.
The car drives fine after ignition and I don't sense any other problems when I drive the car.
Any input on this is greatly appreciated!
Thank You
Old Apr 4, 2008 | 03:32 AM
pmohr's Avatar
pmohr
CEL on?
Old Apr 4, 2008 | 03:40 AM
Reality350's Avatar
Reality350
need more background info..
-What mods do you have on?
-Have you removed any intake mods lately?
-Touched the maf or tb butterfly?
-Tried the TB relearn yet?
I am guessing at an intake leak, I had a similar issue and it turned out to be a small leak at the TB...
Old Apr 4, 2008 | 01:35 PM
KJ1225's Avatar
KJ1225
-I recently replaced my Nismo CAI with the JWT Pop Charger on Stock Z Tube.
-I removed the MAF from the Nismo CAI and placed it into the new pop charger.
- Havent tried TB Relearn (Going to do that right now)
- and no CELs
Thanks!
Old Apr 7, 2008 | 08:04 AM
ladyzed's Avatar
ladyzed
Do an idle-relearn procedure.
This worked great on my car, where when the electric fans turned on, it would drop below idle and sputter too.
Fixed
IDLE RELEARN
- Warm up engine.
- Turn ignition switch OFF and wait at least 10 seconds.
- Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
- Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
- Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
- Fully release the accelerator pedal within 3 seconds after the MIL goes ON.
- Start engine and let it idle.
- Wait 20 seconds
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
