what the?
so i started up the car today and boom died out on me start it up again to rev it a lil and i put my foot down on the pedal to rev it and the car wont rev it just dies out
the battery is brand new and the car has gas in it anyone know what the problem good be?
bad fuel pump??
idk some 1 help me out thoug
04 enthu. z
bad fuel pump??
04 enthu. z
hmm...
I'm no pro when it comes to car issues, but it sounds like you might also have an issue with plugs/wires?(or something related to that) if the car is turning over I would assume there should be enough fuel in there.. but if it dies shortly after... ?
..just a thought
..just a thought
Any codes?
Clean the MAF
Clean air filter
Change fuel filter
Change spark plugs
Check for plenum leaks / vacuum issues
Do the throttle re-learn procedure
All the normal chit
Clean the MAF
Clean air filter
Change fuel filter
Change spark plugs
All the normal chit
hmm well now i started it up today and it works fine
so im guessing somethings wrong with the plugs or the wires
the check engine light is on so im going to take it to autozone tomorow and see what the code is its throwing and run a diagnostic
i think the problem is just with the computer itself..
so took the car to autozone today to read the code
came out as the tps is not responding right that is connected to the cluth
the computer is sending a eror causing me to have the problems
the car only died on me 2wice today
i cleared the code but it came up again after about 10 miles
so looks like im sending the car to nissan to get the item replaced under warrant
ugh
now what no z for a couple a days
sucks!
ugh
sucks!
Originally Posted by gothchick
Any codes?
Clean the MAF
Clean air filter
Change fuel filter
Change spark plugs
All the normal chit
Clean the MAF
Clean air filter
Change fuel filter
Change spark plugs
All the normal chit
How can you change the fuel filter? There isn't one on the Z.
Well, I don't know how you check yours, but on every other Z & G (besides yours), the fuel filter is here. Gotta luv the n00bs on this forum.
Lol~
Are you sure about that?
Lol~
Lol~
