Replacement parts for AAM Fuel return
Hey guys I have been trying to get a few parts from AAM for about 2 weeks now and they havent called me back I contacted them about 4-5 times, does anyone know where I can get the following parts: In-tank fuel pressure regulator plug, OEM quick disconnect fitting, 90deg 04 AN to 1/8 NPT fitting
and 04 AN 45deg to 90deg AntiStatic Coating 5.5" length, all are parts for the fule pump assembly
The parts you are mentioning basically make up the return correction kit, yes?
If so I have no idea on earth where you would get an off the shelf factory regulator delete piece. AFAIK they are custom machined (at least with the CJM kit). The rest of the stuff should be pretty easy.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
