UR pulley voltage problem
Old Jul 26, 2008 | 11:04 AM
JGTC_350z's Avatar
JGTC_350z
Default UR pulley voltage problem
Guys , just want to check if this is normal..
After installing the UR pulleys , now my voltage indicated on the gauge drops do a little above 12v at idle (usually with the stock pulley it's at 14~15V) , but when I rev it up , the voltage goes up to around 14v.
is this normal or something is wrong?
and once in a while i get a squeek from the belt , should i adjust the tension again cause i dont think i should apply any form of lubricant on the belts as some workshop suggested me to do.
Thanks a lot
Old Jul 26, 2008 | 12:37 PM
gmx's Avatar
gmx
I have the same problem also you can notice it also when you lower your
window
Old Jul 26, 2008 | 06:36 PM
JGTC_350z's Avatar
JGTC_350z
yes i have all 3 installed...... well the stock gauge is showing a lil above 12 at idle but at cruise or accel it goes up all the way to 14......
any idea guys? normal?
Old Jul 26, 2008 | 07:37 PM
Spork's Avatar
Spork
Normal.
The smaller pulley turns the belt a little slower. This causes the alternator, power steering pump, etc's pulleys to turn slower. This slower rotation translates to a less than optimum charging.
Old Jul 27, 2008 | 05:30 AM
JGTC_350z's Avatar
JGTC_350z
so why do people want to change it for then?
a bigger concern is the belt squeek , on cold start up it squeeks for 2-5 sec then it wont squel anymore . Should I be worried? cause i searched and a member said if it continues to squel it means tension is not tight enough and will lead to the belt getting "glazed" ..... it's not a continuous squel just on cold start up.. and i did try to press the belt with my finger and there is no slack at all.
need advise on this last concern from experts like u guys.
Old Jul 27, 2008 | 05:38 AM
itpro2002's Avatar
itpro2002
Belt is not tensioned right
Old Jul 27, 2008 | 08:21 AM
JGTC_350z's Avatar
JGTC_350z
itpro2002: since it was installed in a workshop....... is there anyway i can check or re-do the tension myself? there is no slack , looks tight and everything looks like it is in order.
thanks a lot for the info
Old Jul 27, 2008 | 07:07 PM
JGTC_350z's Avatar
JGTC_350z
im more worried on the belt squeel now =\
Old Jul 28, 2008 | 05:03 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Thanks a lot
if the belt squeaks, it is loose. The factory service manual has tension listed for all drivebelts, or you can just do it the manual way and increase the tension little by little till the squeak is gone
Old Jul 28, 2008 | 06:35 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Don't worry, even stock belts/pulleys squeeze (normal cars will do also). Just do what ' Z1 performance ' said, or if you didn't install them urself, take it back to shop and ask them retight belts again. ( will take not even 10 mins )
Old Jul 28, 2008 | 09:11 AM
JGTC_350z's Avatar
JGTC_350z
thanks a lot guys
took the front undercover off and tighten it up myself. do not have a tension gauge like what the FSM said but i tighten a good 1 turn on the idler pulley screw.
How much is too much and what's the worse that can happen on over-tightened belts? will it add additional stress to the crank etc?
Cause I have no idea how much I should tighten cause it looks like i can still give it a few more rounds on the screw.
I didnt put back the undercover just worried that i might have to tighten it again. Do you guys increase it by 1 full round of 1/4 round each time?
and how often do you have to change the belts? want to know if over-tightened belts will shorten the life span of the belts that makes it prone to getting changed sooner.
appreciate all the help guys
PS: Z1_Performance did the UR crank pulley damage your engine hence you swap to the ATI crank damper? shoot just reading your thread now I felt like I wasted some money putting this light weigh UR crank on..... need your comment on this as i rather junk the part than junk the engine =\
Thanks a lot
Old Jul 28, 2008 | 09:21 AM
Z1 Performance
Former Sponsor
thanks a lot guys
I'd recommend doing it about 90 degrees each time...easy enough to tighten, then start it to see if it makes noise. If you live in Dubai and you're getting squeaking, that means it's fairly loose. Yes if you overtighten the belt it will put more stress on it. Belts should be inspected for cracking, etc. every 5000miles or so.
Old Jul 29, 2008 | 08:30 AM
Q45tech's Avatar
Q45tech
Use a belt tension gauge.
http://www.morbark.com/Service/belttension.pdf
Old Jul 29, 2008 | 08:46 AM
Ztalker's Avatar
Ztalker
i had to re-tighten my brand new belt three or four times in order to stop the squeeking. i had the idler pulley removed(excellent mod btw) a couple of months ago. The idea is to get the exact belt tension w/o over tightening.
Old Jul 29, 2008 | 09:55 AM
JGTC_350z's Avatar
JGTC_350z
why remove the idler pulley?
i tighten it already and no more squel but no where in dubai can i find a stupid tension gauge ....... will there be any signs or symptoms of over-tightening? man i didnt know just by modding pulleys can give me such a paranoia headache.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
