Fuel Injector Cleaners
Old Aug 12, 2008 | 03:19 AM
scanall's Avatar
scanall
Default Fuel Injector Cleaners
Does anyone use these on there 350z? STP B12 chemtool ect. What can be used? Thanks
Old Aug 12, 2008 | 04:07 AM
Altimate_Dream's Avatar
Altimate_Dream
Im not sure if I would use any type of fuel injector cleaners in the Z or not. If I did it would probably be a BG product of some type. They use BG at the dealers so probably ok. I think the manual suggests not to use any fuel additives. Good luck. Just my .02 cents
Old Aug 12, 2008 | 04:13 AM
Z04's Avatar
Z04
don't waste your money. a majority of fuels already contain cleaners in them and those "snake oil" products do absolutely nothing.
Old Aug 12, 2008 | 04:51 AM
Dr. Venture's Avatar
Dr. Venture
on occasions i throw in some lubro moly jectron
Old Aug 12, 2008 | 04:58 AM
scanall's Avatar
scanall
what is BG
Old Aug 12, 2008 | 07:09 AM
Giant655's Avatar
Giant655
Originally Posted by scanall
what is BG
Stands for Big Girl. There is a big fat girl in a bottle that they put in the passenger seat that makes the engine work harder to go faster so it burns all the carbon off the injectors
Old Aug 12, 2008 | 07:18 AM
terrasmak's Avatar
None FTW
Old Aug 12, 2008 | 07:25 AM
SupaDoopa's Avatar
SupaDoopa
My Z rides raw, son.
Old Aug 12, 2008 | 07:28 AM
WhiteNoiz's Avatar
WhiteNoiz
+1
Old Aug 12, 2008 | 07:30 AM
Altimate_Dream
http://www.bgprod.com/home.html
Good stuff. Ask ur local dealer about them. Its not too cheap but, works well..
Old Aug 12, 2008 | 09:44 AM
nothix's Avatar
nothix
can anyone else give opinions on BG stuff?
My car has 66k miles and I've never run fuel injector cleaner.
I'm thinking about trying a bottle out to see if I can tell a difference.
Old Aug 12, 2008 | 10:08 AM
Z CRUZN's Avatar
Z CRUZN
I used some Redline injector cleaner ONCE (at 30k miles)....for the next 10k miles, the fuel pump got REALLY loud....more than normal - ha! Finally stopped making the noise & haven't used injector cleaner since.....Just my $.02.....
Old Aug 12, 2008 | 10:12 AM
SuperBlack350z's Avatar
SuperBlack350z
i just took a pic of my BG stuff. FREE BG PRODUCTS FROM WORK FTW!
but i never used any of this stuff. Supposedly good with great reviews and such.
Old Aug 12, 2008 | 10:22 AM
Q45tech's Avatar
Q45tech
Modern returnless injection systems don't circulate gasoline continously thru engine compartment [heat] so they are less prone to breakdown fuel before it is used up........less need for fuel rail and injector cleaners.
Injector cleaners spray the intake valves and piston crowns where the bulk of the deposit build up decreasing flow and raising compression and creating hot spots.
Don't think of them as just cleaning injectors and they make more economical sense.
The miniscule amounts [reduced to save money] of detergents added to gasoline may actually build up deposits after 200 gallons or so important to rotate among the dozens of additives to keep a clean combustion chamber............either by different brands of fuel or external additives.
http://www.smartworksworldwide.com/f...uelbooster.pdf
http://www.valvoline-technology.com/...ic/2007-03.pdf
Old Aug 13, 2008 | 02:28 AM
Z04's Avatar
Z04
show me an independant study (and not some advertising propoganda) that show this to be true, then you would possibly have a good argument for the use of htese products
Old Aug 13, 2008 | 03:25 AM
*ICE*'s Avatar
*ICE*
how about seafoam? I heard so many good things about that. It can be use with anything too.
Old Aug 14, 2008 | 03:35 AM
Dr. Venture
normal techron that you can buy in a regular autozone/pepboys/advanced will work just as fine if not better.
only use it about every 3 months or so or at every oil change if you want. Don't be putting it in every fill up or what not, cause it will cause some slight damage to seals with over use.
Here is the stuff i use at my shop
http://www.liqui-moly.de/liquimoly/p...t00005422.html
Old Aug 15, 2008 | 02:27 AM
specialized5223's Avatar
specialized5223
I used a bottle of Lucas and my **** didn't blow up. I don't think that is in fact helpful. But I tried. I tried.
Old Aug 19, 2008 | 02:32 AM
finalforce's Avatar
finalforce
Its a good practice to use fuel injector cleaners. I used to always use it on my SR 240 and now continue with my 350z. I've been using STP for years and I give it an A+. Be sure however to use it wisely.....after every oil change and also a good idea to go to the gas station empty, use one bottle and fill in tank and put premium gas (half tank) for a good mixture.
Old Oct 5, 2008 | 09:00 PM
gastoneii's Avatar
gastoneii
I use b12 chemtool for the gas tank every 6 months. and I use seafoam (1 can) to clean out my intake manifold through the vacuum hose for carbon deposits and (1 can) into the motor oil to clean piston rings, lifters, valves etc. 50-100 miles before I change my motor oil. breaks up engine build up. done it to the last 3 hondas I've had and 2 toyotas cars and trucks ran up to 300,000+ miles with not one day at a mechanics shop or stealership. my .02
