Cold temp. tranny shifting problems
Old Oct 24, 2008 | 06:47 AM
queasyrider's Avatar
queasyrider
Default Cold temp. tranny shifting problems
My '04Z has just had a tranny and diff. gear oil change. Now I can't shift into 2nd in cold weather, and am getting a whining noise, until the tranny warms up. Could it be due to wrong viscosity/amount of gear oil? What are the specs and grade for trnny/diff. gear oil? Any info would be sincerely appreciated.
Thank you.
KennyG.
Old Oct 24, 2008 | 01:57 PM
BiGGD198's Avatar
BiGGD198
this this just happen after the oil change or you just noticed it louder after?
i recommend using Royal Purple tranny fluid and fill it up til it spills...i have an 03 with major tranny problems last year....but after the change like 3 months ago...i just had my first cold temperature start and works amazing....slides right into gear with a lil grind but thats normal for my tranny....but alot smoother of a shift and after like 2 min of driving works like a charm.
alot of people also recommend that Motul...and theres threads of a "secret recipe", where you mix some oils and it fixes the synchro problem.......thinking about trying that next year since i got nothing to lose if my tranny blows....its a matter of time anyway...haha
Old Oct 24, 2008 | 01:58 PM
BiGGD198's Avatar
BiGGD198
Old Oct 24, 2008 | 02:05 PM
Sounds reasonable. Depends how cold is cold. 32 degrees or less is cold. The motor is cold, the transmission it cold, the differential is cold, the shocks are cold. Cold effects every fluid. After 5 minutes of driving everything should be fine.
Except the struts that hold up the rear hatch. Watch your head.
Old Nov 5, 2008 | 05:35 PM
queasyrider
Default cold weather tranny shifting problems
Yes, I noticed it more after my tech changed fluids. He swears he used recommended viscosity, and checked levels. The diff. whines as well in the cold, until I have about 5 miles on the car.
Should I : 1.Have the fluids changed again? ( seems like such a waste of $)
2. Bring it to Nissan, have them leave it outside on a cold day?
(77k on the Z. I have an aftermarket warranty-Guardian)
3. Live with it, and wait for warm weather?
KennyG.
Old Nov 5, 2008 | 09:44 PM
Escobar's Avatar
Escobar
for those who changed your tranny fluid, which fluid did you put in it to help with the issues? Royal Purple or Motul ? I am about to do a tranny fluid change and want to know what would work best. thanks
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
