Anyone advance the timing?
Old Aug 13, 2003 | 06:40 PM
Juztin's Avatar
Juztin
Default Anyone advance the timing?
Has any1 advanced the timing on the Z? I remember a thread wayyyy back in the day concerning this but I wanted to get some current feedback on this. I heard the safe amount is about a +2 advance. Any1 notice any improvement, or any dynoable improvement? Thanks for any input!
--Justin
Old Aug 14, 2003 | 04:16 AM
VandyZ's Avatar
VandyZ
It only advances the timing long enough for troubleshoting engine problems, thus the chage gets reverted in time buy the ecu. To really change the timing you will have to get a flashed ECU.
Old Aug 14, 2003 | 04:29 AM
j's350z's Avatar
j's350z
Or the SMT6!
Old Aug 14, 2003 | 04:45 AM
sschmuve's Avatar
sschmuve
Ive had it advanced 2 deg., but it really isn't noticeable. I'm glad the dealer did it free for a good feedback rating. They were going to charge me $90. It's not worth paying for, unless you drag your car. Even then, I don't know.
Old Aug 14, 2003 | 04:54 AM
VandyZ's Avatar
VandyZ
Originally posted by j's350z
Or the SMT6!
Really?
Old Aug 14, 2003 | 05:09 AM
FLY BY Z's Avatar
FLY BY Z
There are two ways the dealer can change your timing. One is permanent and the other is not. My dealer did it for free for me the permanent way. It took less than 5 minutes. My cats are out and he checked lean/rich condition and said it looked good/normal. I think everyone has hyped up a bunch of misinformation on the Z and should not overcomplicate the car. Why should I believe the shop guys at the dealer? Well, I sat in the passenger seat while the guy showed me how to do it and considering the dealership belongs to my father, I know that I am not getting BS'd at anytime.
By the way, the timing advance is very noticable. The car is much faster; maybe that is just a good combo with cat pipes (lsdunique) I don't know. But the car is smoother and pulls harder. Find a dealer who will do it for free. They are out there.
Old Aug 14, 2003 | 06:20 AM
Juztin's Avatar
Juztin
Quick question Mr. Potato Head,
Did you do the permanent advance before or after the lsd's? If so did you notice it then as well? From what I can tell, the advance should be helping the low end & mid range torque giving you that oomph right?
Guess I'm just trying to see if I can determine if the advance does give a noticeable improvement seperately from anything else. It makes sense to do is as it should benefit the low & mid range torque w/out cutting off the top end. Thanks for your feedback guys and especially Mr. Potato Head, much appreciated!
Old Aug 14, 2003 | 07:07 AM
VandyZ's Avatar
VandyZ
Could you find out how. This would be cool, because I was shown the Consult tech manual (Z33 specific pages) where it discusses timing advance / retard and it specifically said that this procedure would temporarily change the timing. IF there is another procedure I would like to experiment with this.
Thanks!
Old Aug 14, 2003 | 07:15 AM
cbsuper's Avatar
cbsuper
I'm a dunce when it comes to cars, so can someone explain to me what exactly does timing do and the importance of advancing it?
Old Aug 14, 2003 | 07:30 AM
Juztin's Avatar
Juztin
Physical timing screw to permantently advance the timing by two degrees right?
Old Aug 14, 2003 | 12:17 PM
Chebosto's Avatar
Chebosto
since the VQ has a timing chain, you really cant alter the timing as you could with a honda (with timing belts and adjustability externally), typically the only way to advance the timing is with a Consult or through the core ECU program...
Old Aug 14, 2003 | 04:10 PM
FLY BY Z's Avatar
FLY BY Z
I had the cat pipes in for about 500 miles before I had the timing done. I will call down and ask the guy what is the different step in permanent/temporary adjustment of the timing with the Consult II when I can. The dealership is in San Antonio and I am in Dallas.
Old Aug 14, 2003 | 06:38 PM
webcarconnection's Avatar
webcarconnection
I have my timing advanced and its great but I don't know if they do it the permanent way or not... I check the timing a couple of hundred miles after and it was find but know more than 3000 I haven't check its on... Pot. Head check the steps to follow w the perm. adj please!
thanks!
Old Aug 14, 2003 | 10:27 PM
jeffa's Avatar
jeffa
I had mine advanced 2 degrees. It is permenent through the Consult.
I noticed better initial throttle response, and the car pulls harder in the upper rpm range. Had it done a couple of months ago at my dealer. Did not charge me, and asked how much advance I wanted. You can actually advance the static timeing up to 5 degrees...
Old Aug 15, 2003 | 06:20 AM
webcarconnection
The +5 degrees is for tunning or troubleshoting... is a margin that the consult II have if the car need some tunnig (for any car the consult II can handle) the Z only handle +2 degrees... if you put it in +5 the car readjust to +2.
Old Aug 15, 2003 | 08:11 AM
SlamMan's Avatar
SlamMan
Ignition timing is a measurement in refference to when the spark plug fires in relation to the angle of the crank. This is measured in degrees in relation to the crank being at top dead center, or TDC. Timing is advanced before top dead center, or BTDC to acheive burning of more fuel before the end of the power stroke and the begining of the exhaust stroke.
Edit: 100 posts and I don't even own a Z yet. Weeeeeeeeeeee
Old Aug 15, 2003 | 10:31 AM
Juztin's Avatar
Juztin
More power and less unburnt fuel coming out the exhaust
Old Aug 15, 2003 | 08:33 PM
jeffa's Avatar
jeffa
If you put in 5 degrees of static timing with the Consult programmer, ithe ECU will not readjust the timing back to 2 degrees. The only way the timing can be retarded from whatever you have programmed it to be is if the knock sensors detect spark knock, and only then will the timing be retarded to reduce or eliminate the knock...
Old Aug 16, 2003 | 05:55 AM
cbsuper's Avatar
cbsuper
Thanks for the clarification guys.
Old Feb 14, 2023 | 04:26 PM
Sevenduce72's Avatar
Sevenduce72
Default Yes you can keep the timing where you want it
All you need is a ELM327 V1.5 Auto Diagnostic Tool OBD2 Code Reader Scanner Bluetooth For Android it has to be this one its like 10 bucks then download the app cvtz50 ..it works amazingly and has multiple awesome functions. I didn't believe it either but now I can set my idle up or down. Do the idle relearn without having to do all that crazy stuff I know my cvt temperature and that's priceless if you want to change your fluid link to the obd https://www.ebay.com/itm/262812908727?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=7TnsuN08Q0C&sssrc=2349624&ssuid=qfGR7SBFRkC&var=&wid get_ver=artemis&media=COPY
This is just some of the features
