HKS Earthing Kit.... Where are the best....
Old Aug 15, 2003 | 05:52 PM
SixRB6's Avatar
SixRB6
Question HKS Earthing Kit.... Where are the best....
grounding points????
I need you guys to help me out. This is my first Z and it is a Roadster. But I open the HKS kit and the directions are in Japanese. So I need you experts to help me out.
Where should I run the grounds? and should I put the terminal on the negative ground post on the battery??
Old Aug 15, 2003 | 07:49 PM
vics350's Avatar
vics350
Go to this link and all your questions should be answered. This is what I went by and I did my install in 15 minutes. There are some great pictures in this link which I printed out and took with me to guide me during installation. Good luck.
https://my350z.com/forum/showthread....grounding+wire
Old Aug 20, 2003 | 02:23 PM
SixRB6's Avatar
SixRB6
Thumbs up Thanks Vic!
I will give it a try...Do I have to remove any stock wires? I would assume that I am replacing the stock grounding wires..Yes? And where did you put your circular terminal?
And I also need to let you know that I will have to miss the Shibby's cruise because unfortunately I still do not have a Roadster
I hope to be there for the next one!
gonzalo_300zx
Dec 18, 2015 04:14 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
