Tilton Clutch Problem
Old Mar 13, 2009 | 09:53 PM
Lookthatsme's Avatar
Lookthatsme
Default Tilton Clutch Problem
hey i was wondering if anyone has had a issue with this clutch before? Ive had the clutch installed for a few weeks already. I bought the clutch used the disks (all 3) where in good condition along with the flywheel. I was missing the nuts for the clutch disks and bolts for the flywheel so i called Tilton and ordered them. Then i was missing the adapter plate and throwout bearing so once again i called Tilton and was told to call Titan Motorsports cause they stock them so i did ordered it and received just the adapter plate for the throwout bearing and not the bearing it self. Which got me pretty pissed cause i payed 125 for the kit and 30 to overnight it and received just half of my order. So i went on and bought a new oem throwout bearing. Car was driving perfect until today. When i pushed my clutch pedal down it didn't make the chatter noice like it always did so i knew something was up. I tried to put the car into gear and non of the gears go in like the clutch isn't being engaged. When ever i got to a stop sign i had to turn my car off put it into gear and turn the car back on in order to move but from there it went into every gear expect 5th, 6th, and reverse (it would grind). Any help possible would be great. Im thinking my master cylinder is messed up but i got that changed less then a year ago when i got the SS clutch line put in and my system was clogged (don't ask me why i bought the car used)
Old Sep 18, 2009 | 11:34 PM
PearlZzZ's Avatar
PearlZzZ
I would call tilton directly and ask them. I'm not positive but I believe you need the a special bearing for the tilton setup. Not the oem one. Also I'm going to order the tilton flywheel/clutch setup. Where did u buy yours , and what did it run you?
Old Sep 28, 2009 | 10:59 PM
PearlZzZ's Avatar
PearlZzZ
Bump for anyone knowing where to pick up a tilton setup!
Old Sep 29, 2009 | 09:01 AM
03threefiftyz's Avatar
03threefiftyz
They are not in production any more because of lack of interest. They come up periodically used in the marketplace.. Also, the tilton is a ***** on the street, and there are more friendly clutches that will hold nearly the same power. At this point I think it would be near impossible to find an unused one for sale.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
