squeaky clutch pedal
Old Mar 15, 2009 | 03:56 PM
dkorr's Avatar
dkorr
Default squeaky clutch pedal
Does anyone know if the throw-out bearing and clutch fork is under powertrain warranty? or is it only 3-yr since its part of the clutch as wear-n-tear? I have an 06 with 44,000mi.
Old Mar 15, 2009 | 04:22 PM
mclovin.too's Avatar
mclovin.too
A squeaky pedal? Is it coming from the trans or the actual pedal? If it is the pedal, just spray some type of lubrication on the pedal assembly.
Old Mar 15, 2009 | 08:01 PM
dkorr's Avatar
dkorr
Sound is coming from under the car. You only hear it when pedal is depressed. After some research on forum threads it appears to be clutch fork and/or throw out bearing. I'm over 3yr/36,000mi warranty so not sure if those two parts are warrantied.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
