Coil problem help pls..
Old May 25, 2009 | 01:25 PM
Cyprus-350z's Avatar
Cyprus-350z
Default Coil problem help pls..
i have a problem with 2 coils..i must change it but some one tell me if you change coils you must change all is it true ? i think change only 2.. thax..
Old May 25, 2009 | 02:00 PM
Cyprus-350z
and when the check engine light come on VDCoff and SLIP light comes on same time is it normal ?
Old May 27, 2009 | 02:57 PM
NISMO_558's Avatar
NISMO_558
in english please
Old May 28, 2009 | 04:19 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by NISMO_558
in english please
Dude he is from Cyprus.......do you even have a clue were that is.If the diagnostic test shows that only 2 coils are needed just replace those 2 coils.
Old May 28, 2009 | 05:15 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you may want to try moving the 2 coils that you suspect are bad to other cylinders and seeing if the check engine light follows the coils to those locations. If so, yes, you can just change the 2 bad ones. However, it would pay to check the resistance on all of them, just to make sure the other 4 are perfectly in spec and not also on their way out
the VDC/Slip and Check engine lights can come on at the same time, but it depends what the code is
Old Jun 1, 2009 | 02:40 AM
Cyprus-350z
i change 2 coils and its ok now thanks for help
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
