first performance mod
Old Jun 25, 2009 | 06:35 PM
nismoZnissan's Avatar
nismoZnissan
Default first performance mod
Lately I've been debating which performance bolt-on mod/mods to start with, and what order to go in as I continue to mod my Z. So far my Z is stock other than wheels/tires. The things I've had in mind are:
exhaust, popcharger, plenum spacer, aftermarket clutch/lightweight flywheel combo (not in any particular order)
Any suggestions would be appreciated, thanks.
Old Jun 25, 2009 | 06:36 PM
JZurita's Avatar
JZurita
What are you looking accomplish with your first mod?
Old Jun 25, 2009 | 06:37 PM
03threefiftyz's Avatar
03threefiftyz
what year?
Old Jun 25, 2009 | 06:42 PM
Scott@fontananissan's Avatar
Scott@fontananissan
Vendor - Former Vendor
I've battled with this throughout the years...and it seems my credit card companies have won!!! It really depends on your goals with the car. I am a track minded feller and if I had to do it all again, I would start with suspension modifications first. In addition, I would spend a little extra and work on tightening the loose nut behind the wheel! Take it out to a track day, learn to drive your car the way it is...as you improve, you will quickly find out what needs to be modded first!!!!
Old Jun 25, 2009 | 06:47 PM
JEKL's Avatar
JEKL
What is your budget?
Old Jun 25, 2009 | 07:58 PM
06z33's Avatar
06z33
Clutch and flywheel should come after some modding IMO. Is it going to be a daily driver?And +1 on what year your car is.
Old Jun 25, 2009 | 08:05 PM
doug's Avatar
doug
my first performance mod was Twin Turbo's.. stock rims.. stock everything else
Old Jun 25, 2009 | 08:22 PM
Old Jun 25, 2009 | 08:24 PM
SirSpeedyZ's Avatar
SirSpeedyZ
should be a turbonator
/thread
Old Jun 26, 2009 | 04:31 AM
DozJr7's Avatar
DozJr7
motorydyne plenum spacer
testpipes or hfc
suspension
for the basics
Old Jun 26, 2009 | 07:45 AM
nismoZnissan
it's an 2004, daily driver.
I'm looking for "the best bang for your buck." street reliability with good power. No track yet, just fast street.
and my budget is sort of limited, probably around $1500 for now.
Old Jun 26, 2009 | 07:46 AM
thekinn's Avatar
thekinn
fuzzy dice and stickers.. way under budget.
Old Jun 26, 2009 | 08:04 AM
Hsummer's Avatar
Hsummer
at $1500 you could go with a plenum spacer, intake, and x02
Old Jun 26, 2009 | 05:33 PM
ZGrand2ring's Avatar
ZGrand2ring
y-pipes to free up that congestion on your exhaust. if u dont mind the check engine light, go for test pipes. but they're for off-road use only. use at ur own discretion.
Old Jun 26, 2009 | 07:25 PM
kof0127's Avatar
kof0127
+1, I was also getting too much stress about what to mod first, if you want to get impression from other, put exhaust and intake(simple and also visible to other), Coilovers for a hardcore driving and you can also get the lower looking of your car. I am drifter so the first thing that I put in my car was the LSD, you wouldn't regret to this mod, you will have so much fun with it even you don't track your car.
coilover and lsd are for driving side of you, exhaust and intake are for the impression side of you, even thou everything is brings up the car performance, so it is up to you.
Old Jun 26, 2009 | 07:56 PM
urbanchaos's Avatar
urbanchaos
Get a intake and exhaust and you will be happy for awhile.
Old Jun 28, 2009 | 01:36 PM
damn_rookie's Avatar
damn_rookie
Breather mods first I say.
Old Jun 28, 2009 | 06:22 PM
Subdermal's Avatar
Subdermal
stickers are good for 5hp each right?
Old Jun 28, 2009 | 06:34 PM
black06z's Avatar
black06z
. After seeing/hearing all the mods people have done to their Z's in the past 5 years, Wheels/tires and/or suspension would be the best 1st move.
Old Jun 29, 2009 | 07:33 AM
nismonian's Avatar
nismonian
suspension should be first mod
