2003-2006 MT6 Trans swap please help!!!!!
Old Aug 12, 2009 | 05:23 PM
Ibrown51484's Avatar
Ibrown51484
Default 2003-2006 MT6 Trans swap please help!!!!!
Hey guys i have a 03' with syncro issues. I found a great deal on a 06 trans my buddy wants to sell me for $250. I looked at them today, and there are some differences. First the slave cylinder is internal on the 06 and the 03 is external. Also it seems the starter bolts up in a different spot. I know people are saying these swaps are easy. I just want to know they make everything fit. Please help me..,thanx....
Old Aug 12, 2009 | 05:43 PM
weak 350z's Avatar
weak 350z
06 had external.....07-08 had internal. sounds like you have a 07-08
Old Aug 12, 2009 | 05:57 PM
Ibrown51484
My friend is a Nissan tech he swears it from a 06 i will get the # off of the trans and check myself. He said I would have to swap the cases to make it fit he thinks it can be done but i want know if anyone has done it.
Old Aug 12, 2009 | 06:27 PM
weak 350z's Avatar
weak 350z
I have a 2006 and changed the clutch myself. It has an external slave.
Old Aug 12, 2009 | 06:51 PM
Ibrown51484
Ok he must be mistaken i will call him tomorrow....I am really temped to try to swap the cases!!
Old Sep 15, 2009 | 06:53 PM
kearlthompson's Avatar
kearlthompson
Did you figure this one out? I have the '07 tranny and im attempting the swap to an '04... Trying to figure out my options
Old Sep 15, 2009 | 08:53 PM
kramykram's Avatar
kramykram
i think it is possible to switch the 2 trannies around being that the older style trannies have the starter holes on both sides. the only problem that lays left is the moving of the crank sensor other than that i think the switch could be made.
Old Sep 16, 2009 | 08:04 AM
kearlthompson
Thanks, this was probably the most common idea i've heard. Still really cant tell if the cases will swap but it seems as though this is what i'll attempt.
Old Sep 16, 2009 | 03:14 PM
kramykram's Avatar
kramykram
well you can swap the inside guts. that should be easy. as i said the hr block as i have has the start on the driver side. but when you pull the tranny on the 03-06 you have a spot on the block where you put a cover plate which is where you could you would mount the starter.
Old Jan 18, 2010 | 07:07 PM
raycs7's Avatar
raycs7
Old post, but anyone tried this out successfully?
SharX59
Sep 27, 2015 09:23 AM
