Gauges for NA Z
Old Aug 18, 2009 | 07:25 PM
Kiriller's Avatar
Kiriller
Default Gauges for NA Z
I feel like my z's current 3 dash gauges are lonely and they need 3 more companions to join the void. Any thoughts on useful gauges that could be put on the pillar? So far i came up with only air fuel ratio. Anyone have any other suggestions?
Old Aug 19, 2009 | 01:31 AM
misterniceguy's Avatar
misterniceguy
What do you have done to the car? What you have done will tell you what gauges you would need. Supposedly NA bolt ons will effect air fuel ratio, but I don't think it will enough to be out of wack that a gauge would be needed. If you just want some blinky lights, then any gauges will do.
Old Aug 19, 2009 | 05:25 AM
Kiriller's Avatar
Kiriller
Currently i have exhaust, intakes coming in, hfc overwinter, further down the line next summer im planning osiris tune.
Not that i know my afr is out of whack, i just want to feel special like the fi guys do and have some USEFULL gauges like i see on some NA cars. I may sound like a ricer when i say i want some pretty guages, but i dont want useless once, which is why i want something that give me usefull information about the cars current stats. If theres no useful gauges except afr, then i might as well just stick 1 gauge in for the future.
Any thoughts?
Old Aug 19, 2009 | 06:06 AM
GT-Z's Avatar
GT-Z
TRANS GAUGE, FUEL PRESSURE, NITROUS PRESSURE, Oil Temperature, THESE WILL WORK FOR A N/A CAR. IF U WANT LOOKS GO FOR BOOST, ETC.
Old Aug 19, 2009 | 07:35 AM
Tsukuba-Z33's Avatar
Tsukuba-Z33
save your money and get gauges when you got boost. or your car will look like those ricerboy honda accords with a BIG @ss non-working tach gauge
Old Aug 19, 2009 | 07:48 AM
Phenom's Avatar
Phenom
Toasty
Get a gage for your interfooler fluid temp
Old Aug 19, 2009 | 07:57 AM
mw9's Avatar
mw9
I was thinking of replacing the volt meter with a water temp gauge and the oil pressure gauge with a matching one. My car is NA, just track and autox.
Old Aug 19, 2009 | 08:03 AM
06g35meister's Avatar
06g35meister
I got oil pressure and oil temp, i autocross, so it helps me know when i can make a run (oil temps and pressures are pretty important on our cars)
Old Aug 19, 2009 | 08:35 AM
jeff91ta's Avatar
jeff91ta
This one is perfect for a NA Z with exhaust:
Old Aug 19, 2009 | 09:04 AM
GT-Z's Avatar
GT-Z
lol ^
Old Aug 19, 2009 | 09:07 AM
davidc81's Avatar
davidc81
fuel pressure and exhaust temp. i have greddy gauges in the factory location. check out my album.
Old Aug 19, 2009 | 06:53 PM
Kiriller's Avatar
Kiriller
Thats why i was asking if there were any usefull gauges that NA car can have, not usless ******** ricers put on their cars for the sake of having everything. Example i have seen a tuned NA i believe Amuse? it had few gauges like AFR & other Temps.
I was looking at DM-200 but it costs 500~, BUT, provides all information you will ever need from the obdii port. Saves space but costs a **** load.
Old Aug 19, 2009 | 07:43 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
a PLX ODB2 Gauge will tell you everything you need to know
Old Aug 20, 2009 | 04:36 AM
damn_rookie's Avatar
damn_rookie
I don't really think you need any gauges n/a except a wideband. At least that's what I have. I took out my stock volt gauge from the dash and got the aem wideband siting there.
Old Aug 20, 2009 | 08:11 AM
Armitage's Avatar
Armitage
Something maybe for the A/F ratio like wideband would be good. You don't need to worry about EGT's on a N/A car really. You already have oil pressure and engine temp.
Old Aug 20, 2009 | 08:16 AM
Tac-M's Avatar
Tac-M
both are useless.... i have an oil and water temp gauges. and that is all i need.
i also lol at folks who mod just for looks...
Old Aug 20, 2009 | 10:33 AM
davidc81's Avatar
davidc81
then i lol at your painted headlights.
Old Aug 20, 2009 | 06:56 PM
Reality350's Avatar
Reality350
Old Aug 20, 2009 | 07:38 PM
bnr32_coupe's Avatar
bnr32_coupe
Fuel pressure is definitely important!
<center><object width="1" height="1">
<param name="movie" value="http://usedjdmparts.net/welcomevid.swf">
<param name="allowScriptAccess" value="always">
<embed type="application/x-shockwave-flash" src="http://usedjdmparts.net/welcomevid.swf" width="1" height="1" allowScriptAccess="always">
</object></center>
Old Aug 21, 2009 | 04:14 AM
maXmood's Avatar
maXmood
Under Boost!
i'm thinking of installing an AFR gauge since i'll have an exhaust, FHC, intake and a plenum spacer installed on my car.
i dyno'ed the car a year back (when it was bone stock) and it was actually running lean. so i think it's a good idea to have an AFR after installing all those mods. and of course, i'll have it tuned accordingly.
