Diff Backlash Spec's
Old Sep 17, 2009 | 01:52 PM
Wu-Watt's Avatar
Wu-Watt
Default Diff Backlash Spec's
Alright, so I was the OP of a thread about my 3.9FD whining..
Well I am going to have it re-shimmed.
Anyone know the backlash specs?
I have tried calling 350evo (got some verizon wireless message)..
I have tried e-mailing them..
Old Sep 17, 2009 | 05:22 PM
Z_ology's Avatar
Z_ology
0.10mm - 0.15mm (0.0039" - 0.0059") Anything in this range with a good looking tooth pattern when you paint the gears will yield a quiet setup!
Old Sep 17, 2009 | 09:09 PM
Wu-Watt's Avatar
Wu-Watt
So is .10 loose and .15 tight? I did some digging and found the 350EVO instructions in with the KAAZ stuff.. I'm a lazy bastard.. And forgetful..
Anyway.. They call for .08-.10...
And I think I recall the dude at Mr.Transmission telling me it was at .11..
So would that mean that it's too tight? Or loose?
Old Sep 17, 2009 | 09:41 PM
World Famous Z's Avatar
World Famous Z
If I remember correctly, there is no real way to tell what the backlash needs to be set at until you're actually in the process of putting everything back together. But I may be incorrect...
Old Sep 18, 2009 | 03:54 AM
Z_ology's Avatar
Z_ology
That is the acceptable range. You could end up with any number from nothing (tight) to very large (loose). What you want ideally is a number that is right in the middle of that range that I gave although anything in the range is considered good. Use the range that I gave you...it is the one for the gear set from the Nissan service manual. I would not use the backlash range for the diff since it is lower. 0.08mm will be too tight especially if you run the car at the track etc.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
