Engine Tick!
Old Feb 3, 2010 | 01:32 PM
  #41
mgrotel's Avatar
mgrotel
switch to 10w30 syn from 5w30 syn?
Old Feb 3, 2010 | 01:53 PM
  #42
Zazz93's Avatar
Zazz93
Yeah, If you live in a warm area I'd say 20-50. If that does the trick you got some worn items that have increased their clearences ever so slightly causing the tick. No big deal.
Old Feb 3, 2010 | 03:34 PM
  #43
mgrotel's Avatar
mgrotel
i live in salt lake, so not exactly a warm climate right now
Old Feb 3, 2010 | 04:41 PM
  #44
twitch579's Avatar
twitch579
Just changed my oil this weekend. Been on Mobil 1 since new, Made the switch to Castrol Sytec Blend. I guess this way I get the best of both oil worlds.
For some reason now after the oil change the Tick doesnt seem quite as loud. I went to a G/Z car show and listened to a bunch of VQ's and they all had the same tick coming from the drivers side wheel well. I also talked to the local Nissan Master Tech and he said that they all make that noise. Its just more noticeable after header/testpipe install.
Old Feb 3, 2010 | 05:13 PM
  #45
mgrotel's Avatar
mgrotel
was your noise coming from behind the dash as you were sitting in the car?
Old Feb 3, 2010 | 06:10 PM
  #46
twitch579's Avatar
twitch579
I cant tell in the car due to the drone even at idle. Mainly just from behind the drivers side wheel. When your driving against a wall you can really hear it.
I will try and listen behind dash though.
Old Feb 3, 2010 | 06:50 PM
  #47
mgrotel's Avatar
mgrotel
cool man, thanks. ill try and listen behind the drivers side wheel to see if i hear it there too
Old Feb 3, 2010 | 06:53 PM
  #48
rich2342's Avatar
rich2342
Originally Posted by maximariceboi
Maybe the timing chain tensioner?
bingo! you know since you have a max. ive had a two nissans an altima and maxima with timing chain tensioner click.
Old Feb 3, 2010 | 06:57 PM
  #49
rich2342's Avatar
rich2342
the guide wears away from the aggressive chain and clicks until the motor builds up enough pressure to tense up the chain and it doesnt rub as vigoursly against the guide.
Old Feb 3, 2010 | 07:08 PM
  #50
mgrotel's Avatar
mgrotel
the tick is not coming from the front of my engine
Old Feb 4, 2010 | 09:09 AM
  #51
Wonunder's Avatar
Wonunder
I just noticed a tick as well. Seems to go away after the engine cools. I'm going to try an oil change to see if that helps.
Old Mar 17, 2010 | 02:59 PM
  #52
Weq's Avatar
Weq
Reviving an old thread; interested in any updates as im expericing an similiar issue, ticking from the valvatrain at the rear of the engine..
Old Mar 17, 2010 | 07:05 PM
  #53
MTZ33's Avatar
MTZ33
Could be lifters or fuel injectors.. fuel injectors tend to make a ticking noise...
Old Mar 18, 2010 | 03:32 AM
  #54
Gizloc's Avatar
Gizloc
You have a Valve Tick. If it gets louder with your RPMs then its deff a Valve Tick. You need a valve adjustment. You just need to find out which valve it is, most likely its one of the exhaust valves.
Old Mar 18, 2010 | 03:37 AM
  #55
Gizloc's Avatar
Gizloc
Best way to find out which valve it is you need a screw driver and 1 other person. Tell your friend to rev the engine and before he does you have to put the screwdriver on one of the valves, I suggest you put your ear or your cheeck agaisnt the rubber part of the screwdriver. If you feel the vibration from the tick you have found the valve!!! Its a simple fix but if you dont know what your doing leave it at the shop because the engine needs to be cool before they open her up.
Old Mar 18, 2010 | 04:52 AM
  #56
Zazz93's Avatar
Zazz93
Bad news Gizloc, on the VQ, there is nothing easy about the valve work. A simple adjustment will cost you anywhere from $25 - $600 for parts alone. Unlike most the simple older designs the VQ rarely "falls" out of adjustment. It uses sized cam followers ($25 each) to adjust the height of the valve, so unless the valve builds up residue or gets additional play through seat wear the ticking people hear is not likely due to the valves. Also it seems more and more manufacters are going to this design that increases service cost and decreases servicing intervals. Also labor on this item can't be less than 6 hours because the head basically is taken off (minus the actually unbolting of the head).
Old Mar 18, 2010 | 06:23 AM
  #57
Gizloc's Avatar
Gizloc
Ahh Good point! Wasn't to sure about the valves on the VQ, guess you can't compare 1 car to another. Good information to know though.
Old Mar 18, 2010 | 01:22 PM
  #58
mgrotel's Avatar
mgrotel
mine doesnt get louder when revving
Old Mar 18, 2010 | 03:28 PM
  #59
xilovelsdx's Avatar
xilovelsdx
put 20w50 in that batch!!!!
Old Mar 18, 2010 | 04:22 PM
  #60
mgrotel's Avatar
mgrotel
haha
