SPEC billet steel flywheel problems
Old Feb 6, 2010 | 05:26 PM
\\\Ivan\\\'s Avatar
\\\Ivan\\\
Default SPEC billet steel flywheel problems
I just got a stage 3+ clutch from spec and a billet steel flywheel for my 07 z and just when i was all happy getting it on the crank sensor turns on any one ever had any issues putting on after market flywheels or spec? any one got any ideas to fix it?
Old Feb 7, 2010 | 04:19 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Crank sensor turns on?
Old Feb 7, 2010 | 05:54 PM
\\\Ivan\\\'s Avatar
\\\Ivan\\\
yea, well thats what my tech says
Old Feb 7, 2010 | 07:27 PM
MREDDLE's Avatar
MREDDLE
How is it that you 'know' your crank sensor 'turns on'?
Do you mean you have a code?
Old Feb 7, 2010 | 10:20 PM
\\\Ivan\\\'s Avatar
\\\Ivan\\\
yes
Old Feb 8, 2010 | 05:23 PM
ZSpeedPerformance
Possible that he damaged the sensor during the process or the wrong flywheel was installed DE>HR are different on the toner ring.
Old Feb 8, 2010 | 09:00 PM
gabe3d's Avatar
gabe3d
I've had the same issue when installing my Unorthodox flywheel. For some reason the flywheel was hitting the crankshaft position sensor. I had to have a small shim installed to move the sensor away from the flywheel.
Old Feb 13, 2010 | 10:52 AM
\\\Ivan\\\'s Avatar
\\\Ivan\\\
well my tech finally got it he said he kept nocking out the sensor when he installed it, and so far its running nice put 300 miles already on the flywheel and clutch. really loving that stage 3+ from spec way.... much easier to drive then the last stage 3 clutch i had
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
