Short Throw Shift. HELP ASAP!! Please
Old Feb 17, 2010 | 05:53 PM
350zHermosa's Avatar
350zHermosa
Default Short Throw Shift. HELP ASAP!! Please
I started to install my new short shift, got a call to leave, so I had to put everything back together.
I got as far as removing the top 4 bolts that hold down the rubber boot under the actual boot and the 3 bolts that hold the bracket that sits ontop of the shift ball. NOW when I started screwing those bolts back in and got everything put back together. And got moving.. umm I lost 5th and 6th gear..
WHAT DID I DO WRONG!! PLEASE HELP!
Old Feb 17, 2010 | 05:56 PM
BlueZ33's Avatar
BlueZ33
when you unscrewed your shift **** did you hold the shifter with a set of vice grips or just unscrewed it off
Old Feb 17, 2010 | 06:01 PM
350zHermosa
just unscrewed it
Old Feb 17, 2010 | 06:02 PM
350zHermosa
just unscrewed it y
Old Feb 17, 2010 | 07:04 PM
diablox1's Avatar
diablox1
i can't help you here bud.... but i can warn you that once a mod reads this, he might move/close your thread again.
Old Feb 17, 2010 | 07:09 PM
Emski's Avatar
Emski
you screwed it up by just unscrewing it
Old Feb 17, 2010 | 07:11 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Did you put the plate on wrong? There is the part that works as a reverse lock out maybe you have that on the wrong side? It goes to the passanger side, or maybe the shift lever itself got spun or twisted
Old Feb 18, 2010 | 03:03 AM
ECLIPSEGST25's Avatar
ECLIPSEGST25
do a search for installing a short shifter. I know that you have to cut out a notch on the plate to be able to go into reverse. maybe it is the same for 5th and 6th gear.
http://www.350zclub.org/BM-shifter.shtml
Old Feb 18, 2010 | 05:40 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
when you reinstalled the triangular piece, you did not line it up perfectly and it's too far over to the passenger side - as a result, those gears are going to be blocked. You need to loosen it back up and shift it over slightly. You can do it with the car in 5th or 6th and move the shifter as you move the plate to where it should be and tighten it back down
Old Feb 18, 2010 | 04:01 PM
Zomgfast123's Avatar
Zomgfast123
lmao thats funny
Old Feb 18, 2010 | 04:45 PM
dmroberson's Avatar
dmroberson
+1. Check that plate. the instructions that came with your short shifter should have said something about that too...
Old Feb 18, 2010 | 04:47 PM
Crom's Avatar
Crom
+1 what Adam said... loosen those bolts, go through all the gears repeatedly to align the plate then tighten it back down...
