Clutch Problem PLEASE HELP!
Old Mar 7, 2010 | 05:03 PM
06VenomZ's Avatar
06VenomZ
Default Clutch Problem PLEASE HELP!
I recently installed a Competition stage 2 clutch an flywheel along with a new clutch line and Motul fluid. After installing everything I began to bleed the clutch an realized that pedal was stayin down when pressed. I continued to bleed the clutch but the pedal would still fail to return to normal position after being pressed. I then started the car to see if engine pressure would correct the issue only to see clutch fluid pouring out of the transmisson. I am thinking its the slave cylinder that is broken but before I bought a new one thought I would reach out to the forum. Any opinions would be greatly appriciated. Thanks in advance.
Old Mar 12, 2010 | 11:43 AM
06VenomZ's Avatar
06VenomZ
Replaced the clutch slave cylinder an clutch pedal still won't return to normal position after being pressed. Dropped transmission again to double check the fork an throw out bearing an everything looks fine.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
