need help. error code 1100 after cleanins MAF
Old Jun 1, 2010 | 07:29 AM
R3belzBRN's Avatar
R3belzBRN
Default Need help. error code 1100 after cleaning MAF
Hi guys,
need help on this.. is there such thing as error 1100? try searching for it but i coudnt find any..
what happened was, last week i disconnected the battery for 20-30 minutes to clean the post and terminals. .. connected everything and when i start it the rpm was quite low enough to stall.. gotta step on the pedal to hold up the rpm.. it usually happened during hot start..
so i searched the forum and i tot its because the MAF sensor is dirty.. so just now i try cleaning the MAF sensor using contact cleaner just like few people suggested in the forum. so far what i did was took out the sensor from the casing and sprayed it with the contact cleaner. maybe 2-3 short spray.
when i try to reset the ECU, i got this error.. did try to clear the error but no luck.. did try test driving the Z and so far there is no obvious problem.
post the video to prove the error. will try again tomorrow to reset the error.
neways, thanks in advance..
http://www.youtube.com/watch?v=9Jj7Q8z5LfQ
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
