Help with VLSD fluid!
Old Jun 1, 2010 | 10:18 AM
Terrones's Avatar
Terrones
Default Help with VLSD fluid!
I was told I need to change my diff oil. So I've been doing lots of research on our VLSDs and from what I got(correct me if I'm wrong) the more viscous the gear oil the better the diff will catch, right? So I'm wondering what kind of gear oil you guys would recommend. I was also thinking what if you put the Lucas gear oil stabilizer it says you can put that alone for the diff on the bottle but I'm not sure how that would go over. Also the winter is cold here and the summer is hot so the temperature jumps all over the grid.
Thanks in advance.
-Terrones
Old Jun 1, 2010 | 11:07 AM
OMERTAITALIA's Avatar
OMERTAITALIA
prolly should search theres threads on this
https://my350z.com/forum/engine-driv...ssion-oil.html
Old Jun 1, 2010 | 11:16 AM
Jeff92se's Avatar
Jeff92se
Are you referring to the VLSD fluid inside the coupling itself or the differential oil? I believe these are two very different things (although both reside inside the differential housing)
Old Jun 1, 2010 | 11:55 AM
Terrones's Avatar
Terrones
Well I'm looking for an easy quick fix to my diff so oil for sure and the VLSD fluid itself would be a nice change if it doesn't cost too much. Cuz I don't have the money to get proper diff yet and this one just kinda locks the wheels when it feels like. I can take the same corner with the same speed and angle and sometimes it will decide to spin both tires and sometimes just one with VDC off of course.
Old Jun 1, 2010 | 12:07 PM
terrasmak's Avatar
When you change you diff fluid it does nothing for the VLSD, the VLSD is a sealed unit in the housing
Old Jun 1, 2010 | 12:08 PM
VO...'s Avatar
VO...
Administrator
+1...
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Ace2347
Sep 22, 2015 03:12 AM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
