OS Giken clutch doesn t disengage
Old Jul 14, 2010 | 08:00 AM
SargeZ350's Avatar
SargeZ350
Default OS Giken clutch doesn t disengage
Hi guys
i recently bought a os giken twin plate clutch. my tuner installed it but the clutch wonīt disengage properly. means clutch disengaged and 1 gear selected you start revin and the car starts moving. we tried to adjust the actuating rod but that didnīt make it better. maybe the release bearing is gone.
are there any known problems or solutions?!
Old Jul 14, 2010 | 11:58 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Does the pedal feel good? Hydraulics are good? Can you see the slave cylinder move when the pedal is depressed?
Old Jul 14, 2010 | 12:01 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
make sure your installer used the sleeve and bearing that OS requires - if you use the OEM one, it will not work properly
Old Jul 14, 2010 | 01:46 PM
SargeZ350's Avatar
SargeZ350
Thanks Adam. i already mentioned that. Donīt know if he used that. we will give it a try. pedal feels good. hydraulics are fine. no air in the system.
Old Jul 14, 2010 | 05:31 PM
Brett@AwesomeZ
movement at the slave?
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
