having trouble bleeding the clutch
Old Jul 15, 2010 | 07:40 PM
james3189w's Avatar
james3189w
Default having trouble bleeding the clutch
I have installed a new clutch flywheel and braided clutch line and i cant seem to get any pressure out of it. It moves very little but not enough to move the clutch fork, the pedal also gets stuck to the floor. Any tricks or techniques?
Old Jul 16, 2010 | 03:32 AM
DavesZ#3's Avatar
DavesZ#3
Did you search this forum and run across this?
https://my350z.com/forum/engine-and-...g-problem.html
Old Jul 16, 2010 | 11:06 AM
james3189w's Avatar
james3189w
Yeah I have read that. I have tried the old oil pump technique no air has come out. I have bled it for more than a hour by pumping the pedal and still nothing. Should I just keep at it? Maybe it takes longer?
Old Jul 20, 2010 | 03:57 PM
solidfish's Avatar
solidfish
I recently bled my clutch fluid (stock clutch) and it took me about 15 minutes. That was with me on the floor working the valve and the wifey pressing the pedal.
edit: davids link above shows that it could take longer. I was just replacing old fluid so had no bubbles, thereby faster.
Old Jul 21, 2010 | 06:48 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Well, the fact that you have some movement at the slave is good. Make sure whoever is pumping the pedal for you is doing so nice and slow, all the way from top to bottom. Just keep at it and it should get better. Make sure the master cylinder doesn't go dry otherwise you'll just have to start all over.
Old Jul 23, 2010 | 07:17 AM
kramykram's Avatar
kramykram
get a turkey injector and take the tip off and connect a peice of hose to it, fill it with clutch fluid, then connect the hose to an open bleeder valve, push the fluid in, close the bleeder valve, bleed as normal, rinse and repeat till you have pedal pressure again.
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
