Power loss !!!, Only when it's HOT outside ...
Old Aug 11, 2010 | 12:35 PM
  #41
amr_electron's Avatar
amr_electron
Originally Posted by Tomek350Z
Am I the only one who noticed that in post #4 he states he is using 10W-60 oil? why are you using such a thick oil
True, I use it. I also was advise by some Z owners to use it since we have very hot weather here . You think the oil has any issue with my prob ?
Old Aug 11, 2010 | 03:17 PM
  #42
singh's Avatar
singh
_______________
dude 60 weight oil is pretty viscous.. i would go to a 40 weight if i were you..
and where are you located that it's 120+ degrees out? i'm in houston and we have temperature in the mid 100s and my car never feels like it's losing power..
Old Aug 11, 2010 | 10:36 PM
  #43
Tomek350Z's Avatar
Tomek350Z
Haha, I have never even seen such a weight oil in the states. I would start by ad least putting in the factory viscous oil which is 5-30. You just doubled the viscosity, that is very thick, this might be why it feels sluggish
Old Aug 12, 2010 | 12:03 AM
  #44
amr_electron
I was searching the forum & came across this post,
Originally Posted by NismoZ123
Solution: Yes I solved this.
Have you checked your brake lights...and their fuses?
Have you changed the taillight bulbs at any time....to aftermarket LEDs?
Have you altered your brake pedal switch wiring?
You see, the ECU takes brake pedal signal readings through the tailight circuit. If that circuit is open, or shows very low current draw, you simply will not be able to rev past 3000 RPM while driving - and there won't be any indication as to what the problem is.
Someone needs to post this up on a FAQ someplace.
Let us know if this works out for you.
Could it be something like that ?
Old Aug 12, 2010 | 11:04 AM
  #45
amr_electron
I tried my lights today, They are all working O.K. It's not even going over 2500 rpm today as if the transmission is locked in safe mode
Any way i will take it to the dealer on Saturday.
Thanks,
Old Aug 15, 2010 | 02:44 AM
  #46
amr_electron
Here's some updates if anybody is interested,
I got a call this morning from the dealer. The report says the following:
"NEED TO REPLACE ETC ASSY AN IF NECC, ECM & RE-CHECK", The part name in the report is kinda strange, "CHAMBR THROTTLE" . which as i know is throttle body .
But they quoted me around 1800$ !!!!!!!!!!!!!!!, So i took the car without a fix.
Do you people think that it actually sounds to be the throttle body?, Is it OK to buy & replace it by my own ?
Old Aug 15, 2010 | 02:09 PM
  #47
amr_electron
Any ideas ???
Old Aug 23, 2010 | 08:37 PM
  #48
JOMZSHAKES's Avatar
JOMZSHAKES
I would buy that part and try it, if a new throttle body doesn't fix it it says to replace your ECM.
You'll most likely have to get a ecm reprogramming done at the dealer
but the throttle body you can do yourself unplug battery, install new/used throttle body and then replug the battery.
Throttle body doesn't fix it... take it to the dealer
get ecm
Maybe buy a isothermal motordyne spacer to help with heat?
is your check engine light on?
Malfunctioning ecm would most likely cause a check engine light
Old Aug 23, 2010 | 11:55 PM
  #49
terrasmak's Avatar
Try the throttle body reset, search it and perform it.
Old Aug 24, 2010 | 01:44 AM
  #50
amr_electron
replug the battery.
get ecm
My check engine light is not on, There's no error codes stored even & that made me think that the
ECU is faulty. But, It seems that the ecu is still taking control of the car, For example i removed
my maf to see if the CEL will come on or no, & it did. the VDC is still working cause some times i
will get the slip light blinking when i push the car hard from a stop ( i have 19 inches tires ) .
the cruise control is also working . But i'm pretty sure that there's something wrong within my car.
I will buy & install the throttle body by my own, It's easy i know . courtesyparts.com is no more
selling the TB so i will consider buying it from ebay if i couldn't find one in the junkyard .
I'm not really so enthusiastic to change the TB cause i think that i have another problem, Can anyone explain to me why i can go full throttle only once after i hit the brake & totally stop the car ( even if i didn't turn off the car ) ???? I mean, I will push the car from a complete stop & i will keep accelerating till i go WOT, But once i release the gas pedal ( say i'm cruising at 60 MPH ) i will never be able to get the car back to full throttle ( the rpm will seem like it's stuck & Hardly moving between 2500 & 3000 rpm ) .
Do you mean the idle relearn procedure ?, The car idles perfect by the way, But anyway i will consider doing both idle relearn & accelerator pedal position relearning .
Old Aug 24, 2010 | 05:17 AM
  #51
terrasmak's Avatar
Wow, from what you are saying above, try disco the brake light switch and drive your car for a few minutes. It almost sounds like you may have a faulty switch (or wiring) the car has a throttle cut if the brakes are applied.
The switch is easily disco'd from right above the pedal.
Old Aug 24, 2010 | 06:51 AM
  #52
djamps's Avatar
djamps
If you have aftermarket tails or bulbs remove them completely and do a quick test run. Aftermarket LED tails have been known to do exactly this. They bleed voltage into the ECU making it think your constantly on your brakes so it cuts throttle.
Old Aug 24, 2010 | 03:30 PM
  #53
amr_electron
Wow, from what you are saying above, try disco the brake light switch and drive your car for a few minutes. It almost sounds like you may have a faulty switch (or wiring) the car has a throttle cut if the brakes are applied. The switch is easily disco'd from right above the pedal.
I tried to test this & came across this in the service manual,
- I disconnected switch no 3, But i was not even able to shift ( as if the brake pedal is totally released ). So i couldn't test with switch 3 off.
- I disconnected switch no 8, But the brake lights & the high-mounted stop light was still coming on once the brake pedal is pressed !!!
Which one exactly is controlling the tail lights?
I bought the car about a year ago & the previous owner didn't mention anything about swapping the tail lights, But they look like the OEM ones. they are not the LED ones, but who knows. I saw some threads before about problems with aftermarket tail lights & i think that disconnecting the proper brake light switch will take the tail lights out & i will be able to judge .
I'm just waiting for any input regarding the location of the brake light switch.
Thanks,
Old Aug 24, 2010 | 09:21 PM
  #54
JOMZSHAKES's Avatar
JOMZSHAKES
how is there a check engine light with no stored codes???
vdc working probably on a different computer then your ecm
so i can imagine that working fine
the taillight bulb issue seems worthy of researching
but as a dealer they should be pretty confident with having you replace your throttle body and or ecm to clear the check engine light
they diagnosed that using a code, one they got from your check engine light
if they told you there were no stored codes in the computer that may be them not wanting to tell you the code so you will perform your work with them
instead of doing it yourself.
is your check engine light still on?
go to pep boys or a freinds house that has a code reader, find the code
and look at *********.com to see if theres any tsb's "service bulltins".
if your code points anywhere towards your throttle body - then replace it.
that will most likely be your problem, especially if you paid a nissan tech to diagnose your problem and this is what he would have trusted himself in replacing to fix your car.
trust the diag if it was a real nissan check engine light diagnostic
Old Aug 24, 2010 | 10:50 PM
  #55
terrasmak's Avatar
No CEL, No Codes. Thats we are starting to believe its the throttle cut (from the brake)
Other parts would actually throw a code. Where the pedel actuated throttle cut willnot throw a code, the throttle just believes your applying the brake at all times.
Old Aug 24, 2010 | 10:53 PM
  #56
amr_electron
My check engine light never came on, And this is why i'm lost in space . From my experience with any dealership ( not only NISSAN ), I can tell that you should listen to the voices in your head especially when the problem is not so clear, I mean like the case of no error codes. And in my case i have a feeling that it's not the TB .
I'm now trying to look at the taillight bulb issue ( hope it's the prob ).
Thanks,
Old Aug 24, 2010 | 11:28 PM
  #57
terrasmak's Avatar
Disco your taillights and try, also disco each of the switches on the pedal and try, then also try with each of the switches disco's. Just do every combo to possibly isolate where the problem is.
Old Aug 25, 2010 | 11:25 PM
  #58
amr_electron
unfortunately the brake light issue didn't work . I totally removed the back light fuse from the fuse box under the kick panel but nothing changed .
Anyway, I will order a new TB from E-bay & i will change it hopefully i can get my car back to work .
Thanks,
Old Sep 5, 2010 | 11:10 AM
  #59
amr_electron
So i replaced my throttle body today with no luck. I noticed that the throttle valve is not fully opening when the ignition switch goes to OFF position.
Here is a video Showing the movement of the throttle valve when the ignition switch goes to OFF position. You can see that it is not fully opening, Does it seem O.K ?
[youtube]Yskv5KmIFu0[/youtube]
Share your thoughts...
Old Sep 13, 2010 | 08:40 AM
  #60
amr_electron
Hi Guys,
Over the past few days i noticed that i have some electric issues,
- Power window switches lights are always ON even with the low beam turned off & instrument lights OFF.
- Ashtray bulb is blown.
- A/T position indicator is showing random strange characters ( when the car is OFF ).
- My heated seats stopped working, The switch will illuminate but the seats are not heating ( both sides ).
- I also notice that the AC will continue to blow a little amount of cold air for some time after switching the AC off .
can anyone point me for a reason what can cause my car to act like this.
Thanks,
