Vibration while taking off in 1st
Old Aug 11, 2010 | 01:55 PM
chestuhr's Avatar
chestuhr
Default Vibration while taking off in 1st
It seems every time I take off in 1st gear(MT), regardless of how much throttle I use, I get a rough vibration. Not necessarily harsh but very noticeable. The whole care is shaking, but most likely coming from the front. I hope isn't something major but have any of you had this issue before?
thanks
Old Aug 11, 2010 | 01:59 PM
pcressey's Avatar
pcressey
Does it happen in any other gear... try accelerating in 3rd or 4th with a decent load... could be a broken motor mount.
EDIT: Is it only when you are in the act of disengaging the clutch? or does it happen when the clutch is fully disengaged?
Old Aug 11, 2010 | 02:04 PM
chestuhr's Avatar
chestuhr
Only 1st gear and only while I depress the clutch.
Old Aug 11, 2010 | 02:58 PM
platelo's Avatar
platelo
It did happen to me the other day when I was eating jelly in my car!!
Old Aug 11, 2010 | 05:54 PM
If the car shakes that certainly is not minor. You will have to have a mechanic inspect the suspension and steering linkage.
Old Aug 11, 2010 | 06:27 PM
cskippy's Avatar
cskippy
Maybe try giving a little more gas or easing off the clutch slower (smoother).
Old Aug 11, 2010 | 07:45 PM
NewJoyZ's Avatar
NewJoyZ
sounds like your clutch is starting to slip.
Old Aug 11, 2010 | 08:19 PM
winchman's Avatar
winchman
A clutch that chatters as it's engaging might have oil on it from a leaking seal in the engine or transmission. It might just be that the clutch is worn out, or has some broken springs. Less likely is a problem with the master or slave cylinders. Since the clutch is hydraulically actuated, it's unlikely the problem is with the engine/transmission mounts.
Regardless, you need to have it analyzed and fixed soon. That chattering is really hard on the other drive train components.
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
