03Z Clutch problem
Old Sep 8, 2010 | 10:34 AM
DaveSB's Avatar
DaveSB
Notice how there is a clean spot on your clutch fork near the rubber boot? The fork has dropped down because something broke that holds it to the bellhousing. Either the pivot ball or pivot ball retainer clip. The indentation in the fork should be directly in front of the slave cyl rod. Do yourself a favor and grease everywhere two pieces of steel touch. It'll make your clutch pedal smoother and less likely to squeek. Example: pivot ball, where bearing collar and fork touch, where slave cyl rod meets fork.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
