?? about pro-charger>>>
Old Nov 18, 2003 | 05:39 AM
Pachy-Z's Avatar
Pachy-Z
Default ?? about pro-charger>>>
Hi There:
1. First I would like to know how much hp have you gained w/the pro-charger setup.
2. Can i use a flashed ECU AND CAMS W/THE SETUP?
3.Will the factory clutch absorb the power?
4. Thanks.
Old Nov 18, 2003 | 08:41 AM
spazpilot's Avatar
spazpilot
1. 350-370 depending auto or manual.
2. yes, but talk to technos
3. for a while but look at a new clutch shortly after the install.
Old Nov 18, 2003 | 09:24 AM
Juztin's Avatar
Juztin
The cams will probably either require you to take your care to technos, but seeing since you live so far away, they will most likely want you to have a wideband o2 and perform readings for them so that they can properly adjust. I would recommend taking stock readings with the wb o2, then putting on the cams and taking new readings, then sending the readings over to technos so they can have some comparisons to work with when readjusting the a/f & timing for you.
Old Nov 18, 2003 | 09:41 AM
zland's Avatar
zland
Sport Z Magazine
Be sure you get a cam designed specifcally for FI. NISMO cams etc are designed for NA applications thus sc the motor with those cams would be a mistake.
alex30327
Dec 24, 2002 06:47 AM
