clutch kit and flywheel
Old Jan 19, 2011 | 01:38 AM
z_nasty_one's Avatar
z_nasty_one
Default clutch kit and flywheel
What up folks quick question my throw out bearing is going out and there recommended to do a clutch kit and fly wheel but I have a upgraded clutch but would it be cheaper to do the whole kit and bearing or buy bearing resurface my flywheel and labor or just buy all new stuff help and how much is labor usually on zees for that job thanks
Old Jan 19, 2011 | 03:55 AM
Grammar. Its not just for school.
Old Jan 19, 2011 | 05:24 AM
drivessidewayz's Avatar
drivessidewayz
I would start with more info too. Who is "they"? You have an upgraded clutch, but not upgraded flywheel? What kind of clutch? How many miles on this kit? What makes you think you need a bearing/clutch and flywheel? A job like this depends highly on where you're taking it and who's doing it; there is no typical labor for this job just like any other car.
Old Jan 19, 2011 | 08:12 AM
Erik@R/Ttuning's Avatar
Erik@R/Ttuning
It would likely be cheaper to resurface the flywheel, resurface the pressure plate, get a new disc if needed, and get a new throw out bearing.
Old Jan 19, 2011 | 09:23 AM
z_nasty_one
Thanks for the useful advice unlike the grammar police over hear my reason is I just got my z a month ago so I'm still learning and getting to no it more in to detail since all I had before were simple Honda.
Old Jan 19, 2011 | 03:50 PM
Tbagby350Z's Avatar
Tbagby350Z
Question
Hold on, you said you just bought the car, and you have a upgraded clutch... Are you sure you have one, or did the previous owner just say that. Most of the time if you have a upgraded clutch, you will have a upgraded flywheel. When they did that, they should have installed a new bearing as well.
It is most likely going to be cheaper if you buy a whole new clutch kit, bearing, and have it insalled. Spend the money to get it done right, and you should not have any problems.
I just got a quote for a new clutch kit installed on my 03 Z' from PepBoys. Estimate was like 925.00ish....Sounds like a good deal to me,
Hope this helps...
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
