throttle response alittle delayed
Old Feb 4, 2011 | 05:15 PM
yahmeboys's Avatar
yahmeboys
Default throttle response alittle delayed
ok i hope i explain this good enough but this is the problem.
lets use a scenario. just say im on the highway doing 55mph and i suddenly want to speed. when i slam on the pedel the rpm needle increases in rpm but the engine doesnt accelerate.
So basically the rpm needle rises and the engine responsed like 3 seconds later. is that slight delay normal
Old Feb 4, 2011 | 06:52 PM
Naut's Avatar
Naut
Sounds like your clutch is slipping and you need a new one soon.
Old Feb 4, 2011 | 07:03 PM
yahmeboys's Avatar
yahmeboys
its a automatic. can the clutch go bad in a auto
Old Feb 4, 2011 | 07:32 PM
terrasmak's Avatar
not really, but the trans/torque converter can.
Old Feb 5, 2011 | 01:13 AM
winchman's Avatar
winchman
According to some people, the clutch is ALWAYS bad in an automatic.
Probably what you're seeing is the lag that happens when the transmission downshifts to a lower gear for better acceleration at full throttle. Three seconds is a bit excessive, though. Can you post a video showing the tachometer and speedometer with a sound track so we can hear what's happening? Something similar to this:
http://www.youtube.com/watch?v=DUtcW...eature=related
hopefully without all the camera motion and background music.
Actually, there are several clutches in an automatic. They're submerged in transmission fluid, and hydraulically actuated by the shift body and computer. It takes a lot to kill them, but it can be done with a combination of abuse and poor maintenance.
