First time on dyno with wierd results. Please explain!
Old Mar 13, 2011 | 08:21 AM
kajuraelai's Avatar
kajuraelai
yeah man id take it somewhere else...
Old Mar 14, 2011 | 11:36 AM
djamps's Avatar
djamps
The RPM pickup is probably set for the wrong number of cylinders thus you get a higher RPM reading. Since HP is basically TQ x RPM, you're also getting a higher HP reading than you should.
Old Mar 14, 2011 | 03:34 PM
VO...'s Avatar
VO...
Administrator
404 error...
Old Mar 14, 2011 | 03:52 PM
Sickboy101's Avatar
Sickboy101
"I am the Nightrider. I'm a fuel injected suicide machine. I am the rocker, I am the roller, I am the out-of-controller!"
Old Mar 14, 2011 | 06:17 PM
buzzardmountain's Avatar
buzzardmountain
Go somewhere NOT named Blunt Creations, LLC...
Old Mar 15, 2011 | 01:06 PM
phreaktor's Avatar
phreaktor
Design Engineer
The owner is staying late to do it for me again. Will update...
Old Mar 15, 2011 | 01:24 PM
Zazz93's Avatar
Zazz93
I'm jumping on this bandwagon.
Technical term: Organic-interface error .
Old Mar 15, 2011 | 02:42 PM
phreaktor's Avatar
phreaktor
Design Engineer
305.3 HP (284.4 with Correction Factor) @ 6189 RPM /91.6 MPH
323.8 TQ (301.6 with Correction Factor) @ 3776 RPM /63.6 MPH
Anyone ever heard of Nistune? He's saying I could probably net another 12-15 HP with a reflash.
http://www.nistune.com/
Old Mar 15, 2011 | 02:49 PM
Zazz93's Avatar
Zazz93
Honestly, stick with one of the trusted reflash methods. Also I didn't see the VQ on the list of supported boards.
Old Mar 15, 2011 | 03:28 PM
phreaktor's Avatar
phreaktor
Design Engineer
^ I hear that. Ill be going to JDS Motoring or RT tuning for the tune and coilover install...
Old Mar 15, 2011 | 06:06 PM
350ZTheStandard's Avatar
350ZTheStandard
Originally Posted by phreaktor
Ive never seen that black puff of smoke before. Scared the chit out of me. Thought I threw a rod or domething. Can anything useful be taken from the graphical data at least? I have a serious dip from 2-3...
I have my car on the dyno 3 times and I always see the black puff of smoke at the end of the pull. The best i have ever done with a similar setup to your was 241 corrected at 1 mile in elevation, you should have much better #s than mine being at sea level.
Keep us posted on what happened when a knowledgeable operator is running the dyno. Have you had any tuning done to your Z?
Old Mar 16, 2011 | 04:49 AM
phreaktor's Avatar
phreaktor
Design Engineer
Nope no tune. What kind of dyno?
Old Mar 16, 2011 | 05:10 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Mustang dynos can have crazy results depending on the info the operator inputs. They can change the vehicle "weight" for example and throw everything off. Most operators dont input everything to give you a solid number so I avoid those personally.
On a Dyno Dynamics they can mess with correction factors and throw everything off. For example 1.00 correction is true number. 1.10 is adding 10% which many shops do to try to replicate a DJ. Some even add 20%, its BS.
On a Dynojet which seems to be "industry standard" not much in the way of altering other than a handful of "corrections" and some smoothing, which dont make a big difference.
The first operator should have made sure he was pulling the rpm signal correctly, and then made sure the signal on the dyno screen was matching your tach. Lazy tech man.
If you went back a 2nd time and they told you 3XXwhp, they are still doing it wrong, dont go back.
Old Mar 16, 2011 | 07:15 AM
VO...'s Avatar
VO...
Administrator
+1...
Old Mar 16, 2011 | 09:54 AM
350ZTheStandard
Dyno Jet, what happened when the owner ran your car last night?? How did you car get on this dyno, does it raise up put of the floor?
Old Mar 18, 2011 | 06:40 AM
phreaktor's Avatar
phreaktor
Design Engineer
See post 28... It is a drive up type. I'm never dealing with this place again. They obviously don't know Z's or their dyno. What a waste of time and money. I'm gonna head over to RT Tuning or JDS Motoring when I am ready to have my serious work done. I'm not even letting this place do my coilovers.
Old Mar 18, 2011 | 08:08 AM
RetchedOne's Avatar
RetchedOne
Save more money.. do the coilovers yourself.
And i'm with you.. dont go back to that place for your Z...
Old Mar 18, 2011 | 11:22 AM
  #38
Barnabas's Avatar
Barnabas
National Z Club President
Come to MD ill do your coils for free.
Old Mar 18, 2011 | 11:32 AM
  #39
kacz07's Avatar
kacz07
That video and shop is a joke. That guy sounds like the biggest douche ever. You're probably around 265whp on RT's DJ. My car is there right now.
Old Mar 18, 2011 | 11:33 AM
  #40
kacz07's Avatar
kacz07
Wanna do mine for free? 07-08 Nismos.
