Plenum spacer question.
Old Jul 5, 2011 | 03:07 PM
adeel.rajwani's Avatar
adeel.rajwani
Default Plenum spacer question.
Ok well when i installed my jwt pop charger i know it would throw it into limp mode, because the MAF sensor would trip. i cleared the codes (one of my boys works at NTB) so that is working now. If i install my spacer 5/16th will it trip the sensor or no? because my friend said just to take the battery off so when i install it it would just reset all the codes
Old Jul 5, 2011 | 03:27 PM
DavesZ#3's Avatar
DavesZ#3
If you disconnect the MAF sensor while the battery is connected, then it will throw a code.
Old Jul 5, 2011 | 04:22 PM
saywat?'s Avatar
saywat?
none of that should even be happening. u sure u kno wat ur doing or wat?
Old Jul 5, 2011 | 04:26 PM
Ruthless18x's Avatar
Ruthless18x
^ u sur u shuld evan b uzin a keybord?
Disconnect the negative battery cable before doing the install and it will be fine.
Old Jul 5, 2011 | 04:28 PM
saywat?'s Avatar
saywat?
^ah look like we have a spelling bee queen here
Old Jul 5, 2011 | 04:30 PM
ImWeeZzel's Avatar
ImWeeZzel
Old Jul 5, 2011 | 05:56 PM
Agree. Sensors such as MAF are sensitive to connecting and disconnecting. Before doing this type of work I recommend that you disconnect the battery.
_koubie_
Sep 20, 2015 06:34 PM
