Clutch and Flywheel Question(s)
Old Sep 26, 2011 | 06:03 PM
starbuck's Avatar
starbuck
Default Clutch and Flywheel Question(s)
I've decided to upgrade my clutch and flywheel and I have a couple of questions.
1. I've read that the JWT flywheel is very noisy. How does the noise compare to an ACT flywheel? What about in terms of performance?
2. I'm looking into getting an ACT clutch. Assuming I get the pressure plate used what should I look out for to make sure it's in excellent condition?
3. When upgrading the clutch and flywheel is there anything else that I should upgrade or might as well upgrade since I'm already going to be doing these two upgrades?
Thanks as always
Old Sep 27, 2011 | 12:41 PM
starbuck's Avatar
starbuck
No one?
Old Oct 2, 2011 | 01:36 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
ACT or JWT flywheel is going to cause rattling of the trans gears, They are too light to dampen the engine firing pulses. The only flywheel I know of that will not cause the loud rattle in the trans is the South Bend unit
I would not recommend a used pressure plate unless it has been checked by a clutch builder. New is a better option.
To pick the correct clutch you need to know what power level you are running at and what types of driving you will be doing with the car.
There are many choices in clutch materials and different pressure plate clamp loads out there, Getting the right combo will offer you a clutch that will last as long as possible and drive the best according to your needs.
If you need help choosing feel free to give us a call. # can be found on the website.
Old Oct 3, 2011 | 05:42 PM
SkullxKing's Avatar
SkullxKing
Clutch finally went out on the Z, unfortunatly. I bought it used with a stage 2 excedy. I don't really race it unless Im goofing off with my friends in the backroads. However I'm not sure to replace it with an oem or something performance. An I read article that said factory flywheels can't be resurfaced. I was hoping to get an info before I do anything.
Old Oct 3, 2011 | 11:08 PM
terrasmak's Avatar
JWT, just get one. You will be happy with it. The noise will only bother you if you have a bone stock car. If your lowered, have exhaust etc etc , you will hardly ever hear it.
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
