Top 10 NA Z's
Old Sep 5, 2004 | 05:51 PM
  #101
Blownaway's Avatar
Blownaway
yes, he hit 301 with the same setup as me plus the crawford plenum.
Old Sep 12, 2004 | 01:17 PM
  #102
Barzten1's Avatar
Barzten1
Originally posted by PhoenixINX
250 - 255ish.
Add Nismo headers and cams - Maybe another 15. Might want to wait on the NISMO headers, if you plan on doing the NISMO cams - we've already discovered NISMO didn't do any research about mating their header combo to their cams. VERY obvious that their headers are UGLY corkers once cams are dropped in.
Stillen headers are on the way and was just about to order Nismo cams. Is this not a good idea? Give me some input on what mod to do with the headers cause I'd rather do the install at the same time.
Old Sep 12, 2004 | 07:04 PM
  #103
Zmego1985's Avatar
Zmego1985
I would go with the JWT cams and crawford headers. Then after the installs get your ecu reflashed.
Thanks Glen
Old Oct 28, 2004 | 01:56 PM
  #104
pyroteknix's Avatar
pyroteknix
Not sure where you guys are upto with the list but a couple of weeks ago, I dyno'd at
290.5 bhp @ fly.
275.0 lb/ft torque.
Just had a Unichip installed and dyno tuned as nobody can flash the ECU in the UK and TS won't touch our chips.
That's without the UR pulleys. Actually, most of the stuff in my sig remains in boxes.
Old Oct 28, 2004 | 03:29 PM
  #105
Nathan's Avatar
Nathan
290.5 bhp @ fly.
275.0 lb/ft torque.
Thats 1.5 bhp more than Nissan claims @ fly & would be around 238/245 @ wheels.
Old Oct 28, 2004 | 10:03 PM
  #106
pyroteknix's Avatar
pyroteknix
The Euro spec car has 276hp at the flywheel but with the tilton clutch/fly they worked out my transmission loss was ~30hp.
Could always be dyno bullsh*t, though. Was just nice to see that my mods had actually done 'something' to the power/torque.
Old Oct 29, 2004 | 08:35 AM
  #107
UsafaRice's Avatar
UsafaRice
Ok,
Took it to a Dynojet and put down 259 in 4th and 263.1(.1 matters, I tell you!) in 5th. The operator thought 4th was 1:1, I wasn't sure, so I had him do both. Now, these are listed as "STD" and not SAE. Does that mean the SAE would be lower? A lot? It was 85 degrees out and the humidity was visible (basically had fog in the shop).
The operator said, "Man, you picked about the worst day to get it dynoed." I was there for the Air/Fuel because I'm tuning the juice at the moment, so the power numbers were really nice.
I have the Amuse exhaust (straight pipes, y-pipe, rear section), a KN filter (OEM replacement), and the 350Evo TB.
Can anyone comment on the power I was making, the weather, 4th v 5th gear, and/or the difference between SAE and STD please?
Old Oct 29, 2004 | 08:46 AM
  #108
Anthz's Avatar
Anthz
Default I/E/Pulley/Cats
Im at 257 rwhp, 247 rwtq, with the mods in my Sig
http://www.gurgen.com/clint/G35/Dyno...vs%20Stock.jpg
norrix420
350Z Roadster
May 23, 2022 05:11 PM
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
