how to beef up the z33 engine
Originally posted by FLY BY Z
We have a 4 bolt main so the crankshaft, crank bearings, and the bottom part of the bottom end should have no problem with high HP. The weak areas are 1st - the pistons meliting, 2nd - the rods breaking, 3rd - having an open deck. Solving these 3 problems should make the motor strong enough to handle some superpower. My plans:
Forged rods and pistons (8.5:1)
Something to reinforce the cylinders
Higher capacity oil pan
Lightly ported heads
Tomei 268 cams w/Ti retainers, stronger springs, heavy duty lifters
Some sort of plenum (LSDUnique or Crawford)
ATI Procharger with smaller pulley
TS ECU Flash w/(probably)XEDE Programmer (to monitor/fine tune)
XERD Headers
Already have the exhaust, clutch, flywheel, etc.
THE END.
Sidenote: I may sub the ATI and plenum for the Stillen. Depends on HP/dollar.
XERD Headers
THE END.
Plus 500 for labor will be the whole motor and I suspect about 200 for supercharger labor. Maybe 4G's for a Procharger and you say 4500 for the motor. Not bad for 700 HP.
Less than 10K. Can you say, "Bonus!" Yay end of year. Too bad our year ends in July.
-Bill
Can do the heads ourself. Will probably wind up putting the thing together ourselves. I'll let you know how much it is. Less than what you think. Probably more than I think too. Lets take an avg.
Well, I can tell you exactly how much it's costing me, at cost no labor. Not right now, that info is at home tho
It's less then 10g's, but closer due to the stand alone. Either way, it sucks
I don't like turbos.
Anyways, I care more about bang than buck. Plus, the motor won't hold if I do not build it. I want 700 RWHP not 400.
Originally posted by ZSPEED83
custom turbo kit would make way more than superchargers
Originally posted by ravaz
So your saying I can't hit 700hp with a supercharger?
ZSPEED83, the ATI is uses a compressor that is rated to around 700 RWHP. If the motor can take it, the ATI will put it out. Is that funny or did you have no idea?
