Clutch flywheel help!
Old Oct 12, 2011 | 09:46 AM
SkullxKing's Avatar
SkullxKing
Default Clutch flywheel help!
so clutch went out on the car now, so now i need to switch out, however i dont have , much knowledge when it come to the clutch and flywheel stuff.
i really dont race it unless me and my friends are bored and decide to goof off. in the backroad. i like the stiffness of a racing clutch, cause i bought the car used with an excedy stage 2. there was alot of sound, especially in reverse, if i didnt put it in hard in reverse it felt like the car would struggle, and it sounds like a piece of metal dragging on the ground.
IDK if i should put an oem or another racing clutch. i found a set-up that was an ACT pressure plate, but the clutch disc and and flywheel was a brand called F1 racing. idk if this is a good setup the price was low.
and im a college student, so im actually looking for something at a low price. shoot me some ideas, thanks
Old Oct 12, 2011 | 10:59 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
what mods are done or planned?
Old Oct 12, 2011 | 11:20 AM
Ryan@Forged's Avatar
Ryan@Forged
Vendor - Former Vendor
You may check this deal out. It's a pretty good clutch/flywheel combo that we've been using for years. VERY streetable.
http://www.forgedperformance.com/sto...cat=269&page=1
If you need just the clutch we can set you up with that as well. Feel free to PM or call me with any questions.
Old Oct 12, 2011 | 12:08 PM
SkullxKing's Avatar
SkullxKing
i got an injen cat back, and planning to put a cold air, but thats about it, dont have big plans for this performance wise
Old Oct 12, 2011 | 12:18 PM
Ryan@Forged
This combo is a very mild setup. It's what we usually use as our OEM replacement. It's not designed to handle crazy power, it's designed for the lightly modded Z/G.
Old Oct 12, 2011 | 02:57 PM
There are lots of clutches that will suit your needs. Don't get caught up in the "stage" thing. Stages are not comparable from one brand to another. Keep in mind that if it looks like the OEM clutch it will perform similar to the OEM clutch.
Old Oct 12, 2011 | 05:56 PM
Rob@Z1's Avatar
Rob@Z1
If you want a clutch with some room to grow power wise I would recommend a JWT Combo this setup held over 500ft-lb on my personal car with stock driveability.
http://www.z1motorsports.com/350_g35...oducts_id=2024
http://www.z1motorsports.com/350_g35...oducts_id=2025
If you want something more like a stock replacement, our clutch flywheel is very affordable and drives stock.
http://www.z1motorsports.com/350_g35...oducts_id=2405
This combo also includes a SS clutch line.
Old Oct 13, 2011 | 06:20 AM
Z1 Performance
Former Sponsor
if you dont have any major mods planned, I'd simply go for the OE replacement clutch. No real sense installing something you're never going to use
http://z1auto.com/prodmore.asp?model...ne&prodid=4109
if you want a lightweight flywheel, you have a choice of 2 piece or 1 piece. Either work well, 1 piece tend to be a bit quieter and can be resurfaced at least 1 time in their life. 2 piece units don't get resurfaced, their friction surface gets replaced (it's bolted in place)
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
