Pi-thon Hose Locks/Engine dress up
Old Jan 5, 2012 | 08:03 PM
Dan Garcia's Avatar
Dan Garcia
some more, there's also some green ones but I couldn't find the pictures.
Old Jan 5, 2012 | 08:24 PM
Dan Garcia's Avatar
Dan Garcia
Default found it
I'm sure he's got more of them.
Attached Thumbnails Pi-thon Hose Locks/Engine dress up-102.jpg
Old Jan 6, 2012 | 08:23 AM
IDrm350's Avatar
IDrm350
Originally Posted by Kwame@z1Auto
I had Pi-Thon clamps on my Z back in the day and what a PITA it was to work on the car with those things.
Edit: Found some old pics. Just looking at these clamps makes my skin crawl. They scratched easily when using the supplied wrenches and they were difficult to get torqued and a pain in the butt to remove. I don't think I would install these if I were sponsored by Pi-thon.
I put on a set of these intake locks for a guy who I believe got them from you. It was a pain in the a**. The wrenches were worthless. I spent a lot of time modifying the wrenches with a Dremel to make them work. Even then, I had to cover them with faux suede to keep them from scratching the locks.
Old Jan 6, 2012 | 09:04 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by silvertouringz
ur engine bay is pure zecks
Agreed. Now that I recall, the only lock that didn't seal up properly was the PCV one. I had to add some duct tape to the tube itself to increase the diameter so the clamp would torque down on it enough...
Old Jan 6, 2012 | 09:54 AM
Cass007's Avatar
Cass007
Two words... POWDER COAT!!
Pi-thon Hose Locks/Engine dress up-9.jpg
Pi-thon Hose Locks/Engine dress up-p5091432.jpg
Pi-thon Hose Locks/Engine dress up-1281643781937.jpg
Old Jan 6, 2012 | 01:07 PM
orangeNblue's Avatar
orangeNblue
sadly it doesn't look like he has the radiator hose sizes in the blue....those red ones look really good tho!
Old Jan 11, 2012 | 03:49 AM
tkuntz's Avatar
tkuntz
he must have reposted the add, i see them all for sale still, just not sure that he would have enough of one colour to do a proper replacement and i also don't see any wrenches nor does he say he has any included, might be a tad hard to put on without those bad boys ha... unless there's another way to install them without them?
Old Jan 11, 2012 | 08:52 AM
tkuntz's Avatar
tkuntz
did some more research, and here are the sizes you will need depending on the hose setup you have in your bay, the hose clamps on ebay have different numbers then the ones in these charts, so keep an eye out on the sizeing so you don't purchase and screw yourself ha.... ALSO you may notice on the numbers that it will say for ex 1A-04A, all the A at the end means is the fitting is a HEX style and you should be able to use regular wrenches to install, if it says 1A-04 you will need the special pi-thon wrenches to install and use your fittings properly... just a few things to look for if your shopping around.
Pi-thon Hose Locks/Engine dress up-350z-with-samco-s.jpg
Pi-thon Hose Locks/Engine dress up-350z.png
Old Jan 17, 2012 | 02:03 AM
Mapleleaf's Avatar
Mapleleaf
Pi-Thon Hose clamps should be ready to ship sometime in February. I met with them in Sema so stay tuned.
Old Jan 17, 2012 | 09:09 AM
VO...'s Avatar
VO...
Administrator
^^Thanks for responding Terry...
Old Jan 17, 2012 | 12:23 PM
tkuntz's Avatar
tkuntz
thanks for the e-mail in regards to these hose locks, hope to hear from you soon when they are available.
Old Jan 17, 2012 | 08:19 PM
orangeNblue
Default question
as in they're back in business??
Old Jan 17, 2012 | 08:30 PM
805350z's Avatar
805350z
newbury park again? please say yes!
Old Jan 19, 2012 | 06:11 AM
tkuntz's Avatar
tkuntz
through Mapleleaf (Terry @ Zeetoyz), he was saying that the son of the previous owner of Pi-thon is going to start producing same design of hose clamp but under a different company/name, and should be ready for sale in Febuary.
Old Jan 19, 2012 | 09:36 AM
MUZZY's Avatar
MUZZY
IMO they are terible design. Look up magna-clamps. This is what I will be running. easy to use/replace.
Old Feb 1, 2012 | 08:24 PM
orangeNblue
so is there a heads up thread that's going to come up when these things go on sale again? bc I definitely want a couple!!
Old Feb 6, 2012 | 04:11 AM
Mapleleaf's Avatar
Mapleleaf
Yes they plan sometime this month
Old Feb 6, 2012 | 06:10 AM
  #38
abushong504's Avatar
abushong504
if you want to be a baller, get some wiggins clamps. They are purple
Old Feb 6, 2012 | 06:50 PM
  #39
orangeNblue
I'm too poor to be that baller....$54 for one clamp???
Chris350z03
Oct 8, 2023 07:19 PM
SonnyWu
Nov 24, 2015 08:19 PM
EnjukuRacing
Sep 18, 2015 07:57 AM
PureR3d
Sep 10, 2015 06:23 PM
